MTX 1501D repair help
I have 1.17vac across the gate and source, no dc. Whatever this is on 8 and 11 I cant really zoom on. Either way it is nothing I'm used to seeing. I rarely mess with ic,s as they are rarely used in the pieces I work on. Yes remote voltage is applied the protection light is lit.
Why didn't you get the drive waveform previously?
Do you have a 0.01uf cap that you can install across the gate/source to see if you still have a good waveform?
You appear to have shop hours like I used to have.
In car audio, you have to learn ICs but they're not too difficult if you take the time to do it. Do it once and you're done.
These will typically power up through a 15 amp ATC and I recommended that because glass fuses (which I thought you might use) blows quicker.
Using the highest power inline lamp, if you try to power up through it, does the lamp start to dim, as expected or steady full bright (as bright as it might get on 12v?
Do you have a large 1 or 2 ohm resistor that you could use as a limiter? What about multiple 4 or 8 ohm on parallel?
Why was one of the waveforms slightly lower amplitude?
The reason I ask about limiters is so you could pulse the remote to get the rail caps partially charged before inserting the fuse.
That's a fortune in fuses.
I am not on a dbt right now. The amp is wired directly to a 750cca truck battery. Without the ps fets in the amp it is drawing no current. When I tried to power it up with this battery and the fets installed I did use a 15amp atc fuse like you recommended. I blew two of them before I stopped trying. One of the wave forms wasn't lower amplitude, I changed the voltage trying to get a better view of it. I have a ton of resistors on hand but having a big one or two ohm is unlikely. I guess it depends on how large of a resistor your talking about.
I do have a huge dummy load I built but I just realized I have somthing better. A battery load tester. I measured resistance across the leads and it has no resistance when the button is held. Obviously it can dissipate the amperage as it was designed too.
