Burning DAC - the good kind
So, I just finished up the Opus for the Burning Amp Festival (another kind of Burning DAC 😉) Only got to listen for an hour before packing it up 🙁
More pics of the construction can be found here (full size):
http://www.twistedpearaudio.com/user_gallery/_burning_dac/
Arrrrgh!! You have already built the Metronome ASRC 😎
http://www.twistedpearaudio.com/user_gallery/_burning_dac/DSCN8944.JPG
Anyway a surprice and a wonderful new, it exists 😀
It would be nice to have a review by Burning amp people about different configurations:
USB/SPDIF
ASRC Y/N
BALLSIE Y/N
Filter Y/N
USB/SPDIF
ASRC Y/N
BALLSIE Y/N
Filter Y/N
That's the plan, though it will be less than scientific. We HAVE to try it with a computer- I gotta know!!
Unfortunately, the ASRC is not switchable in the current configuration (the way I put it together). Also, a ballsie is always in the output path, just have a choice of filtered/unfiltered.
Well, would be enough an easy A/B test USB/SPDIF, both with ASRC, with same CD played with CDP and through USB with the ripped version.
Brian,
I was wondering if it was possible for you to please post a quick list of the manufacturer and parts you used in the construction of the DAC for Burning amp. Case, IEC, audio sockets switch, etc.
It looks great!
At least, the case and switch?
Darren
Well, that's easy.
Case is from Par-Metal (20-12123N: 12x12x3" unfinished).
Front panel switch is the same Alpha 3-pos, 4-pole switch we use for the Darwin (Mouser #105-SR2511F-43FN).
I/O Connectors are all Neutrik.
Fuse holder is a Littlefuse from Mouser (576-03453LS7H).
IEC connector is one I picked up from ApexJr.
Power wire is actually some 2-conductor speaker wire I got from PartsExpress (16gauge).
All the red wire is 24gauge SPC (Newark) stranded PVC wire I got on closeout (Newark's Ebay Store).
The balanced output wire is CAT5e that I retwisted into 3-conductor sets.
The single-ended coax output wire is the center of some triple-shielded StreetWires coax I bought about 10 years ago.
The front panel, rear panel, and knob are all custom machined.
All the circuit boards are Twisted Pear items except for the 2-to-1 I2S switch board which I etched, as are the two trafos.
BrianDonegan said:Well, that's easy.
How about something more challenging?
Sorry about the noob question.
It looks like that switch selects either spdif or USB for input, and turns off the unit.
I take it that the input modules (usb,spdif) ouputs are connected to the switch. And somehow power is connected.
I would like to control my DAC in the fashion as I will need to use those inputs.
However, I do not know how. If you have the time, I would GREATLY appreciate either a connection diagram or just text explaining what goes where. All of the other connections etc, I have worked out. Just not how to switch the 2 inputs and power(which I could use a seperate switch but this is neater).
Thank you
Darren
Hi lads, is the LCDPS available as a kit on it's own? Doesn't seem to be an option for that on the site.
Dan
Dan
Absolutely, sorry for the oversight on our part. You can get any on the individual circuits/PCBs that we have in stock. I am not sure what it will cost. I am sure Brian will drop you a line and we will add that option the web site.
Cheers!
Russ
Cheers!
Russ
Brian, Russ any idea when you will start shipping the DAC's? I'm getting a bit impatient 🙂
Is there a chance that you would be using the WM8741 chip on the opus dac soon in its stock form ?
In this case I would be interested in some opus dacs. In pcm mode which is only what matters to me the WM8741 is much better in SNR (125 dBa stereo) specs.
After all wolfson says that they are pin compatible so manufacturers can use them as soon as possible !
Also can I PERFECTLY use the opus board alone (without output buffer or filter ) to a 23Kohms input impedance pro amp ?
Thank you very much, Eric
I'm hoping to try something very close to this in the next week or two - opus direct/unfiltered into an Alesis RA150 which I think is ~20k on the balanced inputs. I've been struggling to find time for projects though, so I'm not exactly sure when I'll manage to try it.
I just read the news on the TwistedPair website so my question is answered. Looking good 😀
Opus works just fine into any balanced load > 1K. Absolutely nothing is "required" for good results. In fact I would say that it is ideal to use it this way if you can. 23K would be a very very easy load.
Cheers!
Russ
Cheers!
Russ
- More Vendors...
- Twisted Pear
- Mr White's "Opus", designing a simple balanced DAC
