Sfernice RTO-20 (the 0R5/20W)
Board looks difficult to mount, with 8 power devices on one side, and 8 emitter resistors on the other side of the aluminum blocks.
(lange imbus-sleutel, zeker ?)
Come and have a look 🙂 (and hear)
You dont need speakers for this, you can just play your music on a crowbar, and the amp can double as an industrial welder😀
http://www.onlycreative.it/en.html said:Technical specs
Power input 230/400V 50/60 Hz 800 A
Power supply 6400 Amp - 1.000.000 mF
Output Power 2 x 60.000 watt RMS Class A
Output multi. 6 x 20.000 watt RMS Class A
(Max output power 160.000 watt)
The power output was measured during a gigantic-ones-in-a-1001-centuties thunderstorm of the 666th kind, there are no written reports, most scrolls where burned in the aftermath, only one word could be read, 'F*c?'. At that time the 'power-input' figure was made by method of guesstimattion.
Spaceships, of the 'Flying Saucer' kind, passing by reported 'NOTHING' (this I got from a reliable source). The guys from ATL deny all.
I do not think that 156uF/Amp is enough for any amp was all the reported.
hal 2013... why do they need so much power ?
To power some reptilian gig deep in the planet's crust.😀
Maybe to power the computer on planet krell...
That is a cool reference, I LIKE IT 🙂
It will be shown at the High End 2013 in Munich.
We have industrial supply in Germany with 3 phases, 360V, 30A. That is around 30kW.
I have such a supply in my listening room because it is a converted car port.
2 x 10.000W amp is possible.
Even that is not enough for that monster.
But is it hefty enough for your Apogees ? (Caliper ?)
No 'Carver Amazing Platinum Edition' is what I am listening to.
This is a no limits all out build, component cost for the amp at 1500 to 2000 Euro's (not exactly calculated).
Super quality build... maybe you could give us a hint on the basic topologies used.....
O.k. here it is 🙂 one 'Transresistance CFB BIGBT Amp, By FdW'
That is what i call a modulated current source. I like it because it is very stable with complex load.
The funny-thing/beauty of it is, there is no compensation (of any sort) in the signal path, there is only a BW-limit on the opamp.
Carver Amazing Loudspeaker (Platinum Edition) | Stereophile.com
