MPP
Hi. Since the official R3 PCB was no longer available, I did my own 😉
I also did a pcb for the pre-reg according to the included schematic. I should have them built by the end of the day.
The latest version of the parts list match these PCB.
  • Paradise_Parts_List_small.zip
Question about the BC327/337 HFE matching. Is it necessary to match all the transistor one one channel pcb, or just the Gain Cell ones (Q2,25,26,29 and Q1,30,31,32). And finally, I guest it is necessary to match both channel together as well to get the same gain?
Thanks.
Hesener Put this mach beter way in the guide.
http://www.diyaudio.com/forums/analogue-source/218625-paradise-builders.html#post3189930
Se post 13
Match 10% or better pick closest matched and fit in groups as in circuit
Imput Current mirrors and soon
To me theres no need to target ripple rejection.. HF is the primary.....
The Paradise has extreme ripple rejection.... all is effective shielded by high impedance current-sources/mirrors. poison is the Hf, that can bleed through stray capacitance.
Curls schematic seems rather fine to me or at least a good start. ut no need for the LM's as the Shunt is already onboard..:9
