This R.Jahre company seems to be a very serious one.
Never heard before.
But,
is there any good technical purpose for plating a cap
with Gold ?
Where would be a source to get some of those.
Samples ? 🙄
Never heard before.
But,
with Gold ?
Samples ? 🙄
I believe the golden one was an anniversary one. I am quite sure that there is no difference but golden. I would expect the 1µF very expensive. Gold or not.
You can call Jahre directly. They also selling it.
Ok,
killer expensive is exactly what i was afraid of.
This gold thingie is what they offer on their page.
On customers request.
Only for "beauty", or maybe for shielding purposes
out in space.....
out in space.....
Thanxalot,10nF is about 10€. 15nF is about 15€. Both 1%, 125V. Just to get an idea. So 1€ per nF.
maybe its worth a sin.........
There are also smaller values. like 100pf or 1nF and so on. And they are just a little sin. The sin for every day. 😀
I am in contact with Jahre. As far as i know they where on the moon.
Also the Intonation tube preamp has them inside.
The designer, Herr Milde, is a good friend of mine since 1983. "Glasperlenspiel".
Reliable Capacitors
This guys make the Teflon caps we use in our Spiral Goove Canalis loudspeakers.
I can talk to them if they make some caps for the Paradise.
This is the only company i know in Germany that makes Teflon caps under the GAD Viva brand.http://www.selectronic-kondensatoren.de/media/selectronicproduktuebersicht.pdf
We can talk to WIMA. They are in Unna, 80km from my home. I would like FKP2 in 1% with copper or silver wires.
I once fried one channel of a DL103. Over night, one regulator burned in my phonoclone. It must have been some hours that the inputs were at 0.6V.
One Channel survived!
Rüdiger
2 times my cascode BJT of the DC coupled input stage died well into hours when doing experiments paralleling more and more jfets underneath until it was heavy for it (below 75% dissipation spec still, but gave up the ghost). After much
Perhaps I'll borrow that one as a signature line someday 🙂.Jfets die gracefully indeed
