The number of topologies is not infinite. We all design circuits that resemble another circuits already designed, more or less, intentionally or unconsciously. So do I, so does Joachim, so do others and Mr. Popa is no exception.
Go on, Joachim.
Go on, Joachim.
Joachim, although you are audio professional, you are also prime example of DIY spirit.
I love reading your posts.
Thanks Pavel. This was a heavy day on my heart. First i felt like an inovator and later it turned out that i am considered a copycat.
Thanks vuki. I seem to have more friends then i thought. Give me a little break but i may come back with fresh ideas.
IF SYN08 felt offended in any way he would certainly say so in very clear terms! Joachim, you quote Solomon; "nothing (totally) new under the sun" : and as PMA implies,virtually everything designed is in some respects a derivative of some thing else.
The skill is to improve and meet ever higher objectives - and in this success usually comes from examining the objective from every possible viewpoint and stubbornly persisting until what is required is achieved. You have succeeded in this area more than most professionals! AND most professionals do not give any freebie, fully thought out and tested top designs to DIY enthusiasts!
Keep up the good work!!!🙂
Hi Brian ! I am really moved by the positive reaction i get. I need some time now to think but i will continue when something worthwhile comes my way. I got a question about current sources and i will answer it. Unfortunately not in the context of the circuit i designed it for because i terminated that project. I was so happy that i got that circuit working and i thought that it was novel in the sense that i use only one amplification stage so fullfilling Orkams Rasor. Syn08 has of cause very good reasons to use more amplification and equalising stages, so has Burkhard Vogel and my circuit was not designed to prove that "simpler is better". It was not even ment as a competition but i was not carefull enough in my use of words partly because i was so enthusiastic. I hope you can forgive me that sin and we can move on to better things.
What is new about that topology? I recommended it with low Rbb' transistors (2N4405) back in 1969, to the Ampex Audio Department, without the servos, of course, as a Sel-sync amplifier.
Hi Joachim,
it strikes me hard to see these "Forum madness" grow
everywhere.
Like the others you should take it easy and go further.
Because for whitch car were the wheels newly invented ?
Hope to meet you again @ FF11.
Cheers
peter
everywhere.
Cheers
peter
John, that´s what i said, nothing is new and you are one of the few here that was ALWAYS there from the beginning if i do not count early Marantz and McIntosh. What i thought was new is the amount of stable feedback and speed i got by the particular choice of components. So it was like cooking an old recipy with new ingredients.
The mistake i made was not reading the copyright portion on the synaestesia website and i used some techniques proposed there without correctly identifying authorship and history.
I do not know if Burkhard Vogel reads this but i "stole" some ideas from him too, so excuse me Mr.Vogel that i did not inform you before i put that in words. There was another BIG mistake i made : I should not use the word "commercial" on a DIY thread, but fear not: There is not even a PCB existing for this prototype.
What it proved though is that a global NFB stage can be made that does not loose "single electrons" as Malkolm proposed in his legendary "Essex Echo" musings. At least my hearing is not good enough to differentiate that. And i did not listen to my inner voice that said "free your mind".
Hi Peter, sure, when i still live next year i come to the FF11 even if i have to crawl. That was the best vacation in years including "Gruppendynamik".
I was putting this topology in its place in history. Your approach is certainly more evolved than mine, 42 years ago, but it is the SAME topology. What gets me is Syn08 thinking it his topology, and that you 'stole' it from him.
One might as well ask where Syn08 got his complementary jfet topology from, in a previous circuit?
Joachim a true gentleman
Dear Joachim,
Now it's my turn to tell you something.
You are a true gentleman 😉 just the fact that this grabs you the way it does says clearly that you are a gentlemen and a human being with feelings, and I admire you for that ! (for the record: I know the guy 😉 ).
There are few peoples on this globe that get to the TOP like you did, and stay the same simple and humble guy that you are, who wants to giveaway many many ideas to others, for them to learn from you experience in the audio world and from your mistakes also like you thought me a few times 😉
Dear Joachim, just look at it this way, the higher you get the more wind you catch ! The thing is now to keep up the good work and be and stay flexible.
Keep up the good work and if I can help you in any way, don't hesitate to ask and.............. consider it done !
Best regards,
Atb,
José
Audiofanatic 🙂
Dear Joachim,
Best regards,
Atb,
José
Audiofanatic 🙂
I think it was particular the idea with feeding in the PSU common mode that really bugged him and i must admit that i have not seen that before. The tragedy is that i could not make it work in my circuit and it is not implemented in the playing prototype. Maybe i could make it work after more study but this case is closed for me. Give the king what belongs to the king we say here.
LATE EDIT:
I should have added Nelson Pass as being one professional who has the DIY man's interests at heart and who gives very liberally in that direction. I may well have missed some but I keep my interest here to the things of greatest interest to me.
Joachim, I would agree that a common mode servo using the power supply terminals is somewhat unique, but that is NOT what you used, so what is the problem? Also, I am NOT taking credit for a single ended fet or transistor input stage with an op amp second stage, that was standard design even in the late 1960's. Keep up the good work and remember who your 'friends' are, and you might note that I take a lot of 'flack' around here also. Comes with the territory. Feed the animals and some get jealous and bite you. ;-)
Can someone explain to the less versed among us, what exactly is original in syn08's circuit?
http://www.synaesthesia.ca/images/HPS51-headamp-sch.jpg
Is the jfet+bjt cascode in the first stage original work? Or the transconductance/transimpedance nature of the preamp? Inquiring minds want to know.
Back to circuit design i put a lot of thought into your proposal that there could be FM modulation in amplifier stages. Last week i made a series of measurements on a RIAA stage.
I started with an input of 0.5mV and raised the amplitude in stages up to 20mV. I observed the ouput with a 1kHz and 10kHz squarewave differentiated by a Lipshitz anti RIAA. I also observed the level of a 1kHz sine and up to 20mV i could not see visible clipping in that particular stage. What i could see was a change in the shape of the squares, first barely visible and then more obvious with rising amplitute. I then made precission measurement of the RIAA acuracy at various amplitudes and i could see chages in the microstructure of the amplitude response. The worst case was a drop in amplitude of 1dB at 20Hz at very high level. I again looked more closly to the squarewaves and i could observe a very slight "kink" in the leading edge at high volume.
My conclusion was that this stage has a slightly varying frequency response and time domain behavious over level. OK, 20mV is very high, my Titan gives out only 0.5mV @ 5cm/sec but the measurements are real and repeatable. I do not know if this behaviour is typical, good or bad because i did not try out how other stages behave under those conditions but my conclusion is that it is not suffient to measure RIAA acuracy to 0.1dB
precission at only one ( arbitrary ? ) choosen level of say 1mV input.
Iko, i already mentioned what i find unique. Maybe i have overlooked something that others find. I also accept the complete circuit as a whole as unique from an holistic point of few as a mix and match of elements that work together for a total result. It is like a new picture from the same caleidoscope. A new twist bringing up an unexpected view.
If that's the RIAA HF EQ, then the caps must be pretty large (I suppose the resistors are small, thenths of ohms, to keep the noise low).
Hi Joachim
I also find this question interesting. Do you mind elaborating?
