kestrel, just double checking, but I took it as a fact that you only needed 16 opamps. This is true if you don't need the input buffer or the extra volume adjust output buffer. (each output is buffered before that stage anyway) If you wanted to totally populate all four boards, you'd need 4 sets of opamps, not two.
1 full MOX = 8 opamps (4 dual)= 1 set of opamps
Just FYI, I got a call from Electronix. I got the last of their 2SK389 stock and their lead time is now unknown. Apparantly their supplier is totally out of stock. Sorry folks.
MCM has stock on hand, but a higher price.
tiroth said:Just FYI, I got a call from Electronix. I got the last of their 2SK389 stock and their lead time is now unknown. Apparantly their supplier is totally out of stock. Sorry folks.
You should order 100 (or whatever the demand is) or so from MCM and allow for the option of purchasing them with the boards, as the price is quite a bit lower in quantities over 100.
Brian
Bass management?
Could it be used for bass management?
If yes how many boards I should use?
Vlad
Vlad
he may be referring to the outlaw IBCM, which is a 5 channel (or could be a two channel) crossover for sending low frequencies to the sub.
It’s my fault what I didn’t clear express myself. What I’m like to have is to direct low frequency in subwoofer. What I meant is to relief main speaker from low frequency – from 40 to 90 Hz region. I think it called hi pass. I didn’t do my homework yet. I’m taking advantage from yours expertise. In my opinion –I could be wrong- majority of decent system will benefit from it.
Is it possible to incorporate variable phase delay in this crossover?
Vlad
Vlad
you are looking for something like this:
http://www.outlawaudio.com/products/icbm.html
i THINK this should be able to accomplish what you want, but we will see what others think, now that they have a better idea.
hey, you are from denver! small world.
Vladco said:It’s my fault what I didn’t clear express myself. What I’m like to have is to direct low frequency in subwoofer. What I meant is to relief main speaker from low frequency – from 40 to 90 Hz region. I think it called hi pass. I didn’t do my homework yet. I’m taking advantage from yours expertise. In my opinion –I could be wrong- majority of decent system will benefit from it.
Vlad
Bass management
Hello,
This is regarding the question about bass management. The way I understand bass management is a setup where the bass information from multiple channels are LP filtered and the signals are then added to ONE channel for a subwoofer.
So to make a circuit for bass management we need a number of LP filters (Witch we have), and a summoning amplifier with as many inputs as we have channels. Maybe some sort of phase control is a good idea also. Anyway the summoning amplifier and phase compensator circuits can be build relatively easily on the part of the PCB meant for prototyping.
I hope this clears up the questions
\Jens
Hello,
\Jens
.... one mil is?*)JoeM said:Wow! That board is over 1 square meter!![]()
Mil in Swedish is 10 km.....
*) Correct 0.001 inch.
Mil
HI,
Per you are right 1 MIL = 1/1000 inch.
The only problem is the size of an inch.....there are, as far as I know both UK and US inches....?
1 inch aprox = 2.54 cm
\Jens
HI,
\Jens
Bass management
Vladco,
Thanks for clarifying. As Jens and cowanrg have said, the MOX boards can handle the filtering side of this task. But, there is no circuitry on-board to do summation or phase adjust. As such, I wouldn't recommend it to you as an out-of-the box solution. If you are able to do some work in the prototyping area, though, it can be used for bass management.
All pass filter
http://sound.westhost.com/dwopa.htm#allpass
General opamp info and summing amplifier
http://en.wikipedia.org/wiki/Operational_amplifier
Vladco,
All pass filter
Jens, there is fortunately only one type of inch when we are talking measures in modern life. For the record also it is not approximately 2.54 cm (or 25.4 mm as some of the Non-Scandinavians would say). It is EXACTLY 2.54 cm BY DEFINITION to save us trouble.
As for weight units. After the first 1023 variations, forget it....
I thought it was 25,4002 mm.It is EXACTLY 2.54 cm BY DEFINITION to save us trouble.
As long as I am able to acquire stock, I will also offer the 2SK389 at cost, 2 for $5. This is 30% less than the best price I have been able to find for small quantities. (I want to ship in pairs so I don't have to break the tubes down too much)
If anyone knows of a cheaper quantity source in the U.S. that actually has these parts in stock, please let me know!
(My cost is 100 for $215, $15 shipping, ~4% fees, about $2.40 each assuming I don't end up with leftovers)
tiroth, just need something plain and clear...
the price for opamp boards is a set of 8boards @ $5/set? or $5/board in set?
in wiki we write the number of sets we want to buy? or the number of boards?(I see orders with 20, that would be 160 boards if it is per set).
thanks 🙂
thanks 🙂
The price is 8 opamps for $5
1 set in the Wiki = 8 single opamps (4 dual opamps)
EDIT: Fixed the typo. Thanks DT. No need to confuse people further. 😉
tiroth said:The price is 8 opamps for $5
1 set in the Wiki = 8 single opamps (5 dual opamps)
You mean 4 dual I guess 😉
- Group Buys
- MOX-like crossover and discrete opamp group buy
