MOX active crossover buy
pinkmouse,
That's a good idea. There is no problem with the topology, since the inverting input is already "free" for use as a balanced input. I'll see if I can squeeze some additional pads in to accommadate the extra resistors and inputs.
kepa1+APK,
I will be creating a stuffing guide. I'll post some more info on my site tonight.
Order form
http://tiroth.brinkster.net/mox_order2.html
Size: The boards are 3.09"x2.9" (79mmx74mm)
On-board pots: I have added space for a 3-terminal pot on each channel. There is limited functionality from this though--this will work great if you have the amp in the same box, but it won't be useful if you need a line driver, because there is no buffer after the pot.
Balanced out: I'm sorry, but this board just isn't going to support balanced out. Using normal opamps the size of the board would increase almost 100%, and even using something like DRV134 it would be 50%. All is not lost, though--pseudo-balanced works fairly well in most cases, especially if you have a high quality receiver.
Of course, one could always add buffers or balanced drivers on a small protoboard.
Here is the new layout. The ground plane is moved because it is a pain to keep ripping it up for each change.
http://www.anidian.com/doc/moxlite_v22_board.pdf
Here are the actual measurements from the prototypes. This is for a real set of active loudspeakers
Low pass: 320Hz, Q=0.5
Band pass: 320-3200Hz, Q=0.5
High pass: 1600Hz, Q=0.5
The red trace shows the high pass output, the blue trace shows a parametric notch filter centered at 12kHz, gain -3dB, Q=4.
I can see from the HF measurement that I need to reduce the ground fill a bit around the HP section. I thought that simply moving to a single-side fill would be enough, but I can see there is still a little too much stray capacitance.
