MOSFET Amplifier IRFP240/IRFP9240
Yes, it's singing!
High offset as expected.
I have try many bc556 but offset is 156mV always.
This first try is using +/-35v.
I will test using +/-50v latter.
IRF... "GCE" silk, left over from a IGBT design? :)
A burned pair of Mosfet and a smoked speaker,when one side of power supply, (+/-50v)disconnected by accident
Was it one of those quick connects? that I dis-like, because I think they are cheap and unreliable, the contacts loose grip after only a few insertions. I like terminal blocks instead, more expensive but you get what you pay for.
Add some rail clamp diodes, protection ckt maybe could have saved the speaker. I hope it was a junk/test speaker.
I smoked my amp too, 2 pairs of MJL3281/1302 as I did not have a proper heatsink. All in the name of science.
Mosfet Amplifier test.
+/-50v
idle=20mA
I don't think that is good measurement amplifier....
IMD is the highest ι've ever measured!
Sorry about that. I copied the layout from post #1126. Here is a layout with the ground separated and the outputs closer to the edge. It also has a trimmer for adjusting the offset. If you want PDF for etching or photo resist let me know.
Blessings, Terry
Blessings, Terry
1k feedback resistor must be connect to input (signal) gnd and power gnd close to 10R/2W resistor.
