Mosconi amp fault
sorry, i think thats what i meant a couple posts ago
"well, i was wriggling the rca leads and the voltages changed. i swapped them with a new set and the voltages were the same. I rechecked the voltages at the speaker terminals whilst bypassing the two caps and found that c10 was the same as c9 both 2.5.
I haven’t decided against the tutorial it is on my very long list of to-do’s this week
It’s my amp and I am keeping it
I do have a good desoldering pump
The cap we have determined is faulty doesn’t seem to be available as I have tried to find the same one and haven’t had much luck
You don't typically find the same exact capacitor. You look for the correct value in the same or greater voltage rating that will fit in the allocated space. You could even use a leaded capacitor (leaving leads ~1/4" long) if you fix it down to the board with a suitable adhesive (not super glue).
