The math doesnt lie and what it says with Global negative feedback you can use anything you could ever imagine for the output stage, the worse the better, so long as it is sufficiently biased and has sufficient input impedance. Global negative feedback cannot fix crossover distortion. The output stage has to be adequately biased for feedback magic to take over. I know someones asking wheres the math for class D? Its the same math however focus now shifts from bias to the switching frequency and how fast those outputs can switch, if the switching frequency is 500kHZ can those outputs switch at 5Mhz? Class AB and class D seem to be staying a little longer.
If the output stage is not enclosed within the feedback loop, then it better be great, probably non switching and deeply biased in class A and very linear.
Tales in the wild.
Tales in the wild.
This is a variant of the parallel output stage on Darlington assemblies. Perhaps the author of its use could have been Nelson Pass))).You could use whatever you fancy such as this Nakamichi non switching output
That's right.If the output stage is not enclosed within the feedback loop, then it better be great, probably non switching and deeply biased in class A and very linear.
To understand this conclusion, deep knowledge of mathematics is not required; many even novice radio amateurs know this.
Any amplifier measurement can be a fad if taken in isolation. Measurements are snap shots in a window frame of a bigger picture, there could exist excitement outside that frame.
Noise in context
On a sunny day a few things may influence your experience; some wind, some humidity, ocean sounds, wind against the grass, a cool drink etc. These is essentially noise. We talked of a sunny day, where and when? What's the character of the amplifier?
Noise in context
- Morpheus ultra low THD
