Moode Audio Player for Raspberry Pi
Further to my post above I think there are other odd things happening in Dual Stereo but I need to investigate more.
Edit: No sound from the Sub outputs in Dual Stereo, upsampling to 384kHz. Dual Mono plays only through the L channel. I'll have to work systematically through the settings, because I thought I had Dual Stereo playing OK at one point!
Hi and thank's for 3.8 !
I have Adv. Kernel LT and 32 bit, 352.8 kHz, DUAL-MONO (Piano 2.1+Kali) configured but only get sound from one channel. Have inverted the RCA connectors re-plugged them, etc. but still, only one channel active. No big deal 🙂
All the Best
Input Processing
Source: Airplay stream
Encoded at: Unknown
Decoded to: 16 bit, 44.1 kHz, Stereo
Rate: VBR
DSP Operations
Resampling: off
Crossfeed: off
Equalizer: off
Chip options: FIR interpolation with de-emphasis, gain=0 dB, boost=0 dB
Volume: Software (MPD 32-bit float with dither)
Output Stream
Format: 32 bit, 352.8 kHz, Stereo
Rate: 22.579 mbps
Audio Device
Device: Allo Piano 2.1 Hi-Fi DAC
Chip: Burr Brown PCM5142
Architecture: Sigma/Delta Advanced Segment 24 bit 192 kHz
Interface: I2S
Just updated to 3.8 all is well so far but:
1) the configuration screen for System reports the file system expansion status as always unexpanded (you can check it with the system info pane though)
2) ssh login changed from pi:raspberry to pi:moodeaudio which now that I look is in the setup guide but not the change log.
I just ran a quick test and no issues with file system expanded message. Below are the DF's. The logic in moOde is to check /dev/root Size. If its > 3G then "Expanded".
Maybe a stale Browser cache?
-Tim
BEFORE (Fresh Image)
pi@rp3:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 2.5G 1.4G 1000M 58% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 465M 0 465M 0% /dev/shm
tmpfs 465M 6.5M 458M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 465M 0 465M 0% /sys/fs/cgroup
/dev/loop0 192M 192M 0 100% /var/www
/dev/mmcblk0p1 42M 21M 21M 51% /boot
//moode/USB/EXFAT-256GB/Audio/FLAC 2.5G 1.4G 944M 60% /mnt/NAS/Music
tmpfs 93M 0 93M 0% /run/user/1000
pi@rp3:~ $
AFTER (Expanded on 8GB SD Card)
pi@rp3:~ $ df -h
/dev/root 7.3G 1.4G 5.6G 20% /
pi@rp3:~ $
hi Tim
Exactly I want to edit in WWW file. I want to improve the interface in my opinion. I do not think it is necessary to lock this information. Because of that I bought the open source license plate.
It's not "locked". Its a squashfs and all you have to do is un-squash it if you want to write to /var/www, then you can re-squash it afterwords if you like.
-Tim
-Tim
Cleaned cache in the browser, refresh throught Moode Home Page
Still same report
But i think it is expanded... is it?
/dev/root 15G 1.4G 13G 10% /
//192.168.2.2/Flac 299G 184G 116G 62% /mnt/NAS/Flac-Pc
//192.168.2.1/sda1 2.8T 1.7T 1.1T 62% /mnt/NAS/Audio-SD
//192.168.2.1/sdb1 1.4T 673G 725G 49% /mnt/NAS/Audio-HD
All the Best
Input Processing
Encoded at: Unknown
Rate: VBR
DSP Operations
Resampling: off
Crossfeed: off
Equalizer: off
Output Stream
Rate: 22.579 mbps
Audio Device
Interface: I2S
The Piano 2.1 has two hardware volume controllers. I've added code so that MPD Hardware volume operates both of them in sync but the Airplay receiver (shairport-sync) will only use one of them, the Main "Digital" volume controller.
The configuration you need in order to use Airplay with the Piano 2.1 dual modes is as follows:
1) Set MPD volume control to "Software". This will set both Piano hardware volume controllers to 0dB (100%)
2) Set Airplay volume control to "Software"
Btw: Allo is working on a nice driver mod that will provide a master volume control. I'll be testing this in the near future 🙂
-Tim
So I started again from scratch, reflashed the card, and now I have Dual Mono playing through both channels. LL Kernel, 32 bit 358.2kHz upsampling
Are you also using Kali?
Btw, I've discovered a bug in the code that sets Driver options. It will mess up the dtoverlay= setting in /boot/config.txt. You end up with multiple occurrences of the driver option like the example below.
dtoverlay=allo-piano-dac-plus-pcm512x-audio,glb_mclk,glb_mclk
Please check /boot/config.txt for this issue and edit it manually to correct the issue.
-Tim
Still same report
Yes its definitely expanded.
What is output from the cmd below?
df / | grep '/dev/root' | cut -d' ' -f9
-Tim
-Tim
Thanks Tim. Yes I'm using Kali, playing fine in Dual Stereo now. I checked dtoverlay and it was OK.
