Moode Audio Player for Raspberry Pi
The reason for this is that in both cases the DNS service on my Router/Access Point is resolving the symbolic name into an IP address.
It's a different story if one tries to locate "http://moode.local/" when the Moode Player is running in AP mode. Then my Router/Access Point is not involved (it's a whole different network) and my Android phone fails because it doesn't talk mDNS. I don't want to buy a premium copy of Max2Play in order to run it in AP mode, but I'm willing to bet that my Android phone wouldn't find it if I did.
YMMV.
Regards,
Kent
Sorry no I meant "http://max2play/" to log into the Web GUI for configuration.
Sent from my LG-D855 using Tapatalk
It seems that on most Android revs mDNS resolution isn't supported by Android core code, but by individual licensees - so LG may support mDNS resoiution, while Samsung might not.
This is becoming more of an issue and I suspect there will be a change with Android soon.
For those revs that have mDNS, but don't resolve .local, that is because they ignore the DNS server returned by DHCP and just use Google's 8.8.8.8 amd 8.8.4.4, therefore they can't resolve .local addresses.
There is a workaround:
Code:
Settings > WiFi> your WiFi network's entry.
Long-Tap the entry, chose to edit.
Activate Advanced settings
Switch from DHCP to static, and replace the first DNS server
(usually 8.8.8.8 ) with your own (your router, or the default ip for Moode AP)
Save
Now Android should use your DNS server first, and switch to the secondary
 only if yours cannot resolve. Which means "moode.local" should now be found
Aha! Success!
Mpdas needs to have MPD running, so adding the systemctl start mpdas to the worker solves the startup problem and its scrobbling away 🙂
So what did I do?...
I followed your instructions - worked perfectly, except wget - I used:
Code:
wget [url]https://github.com/hrkfdn/mpdas/archive/0.4.1.tar.gz[/url]
Which I got from the AUR repository: https://aur.archlinux.org/packages/mpdas/
Yes fixed ip through chrome on a windows browser. Here is the aplay -l output;-
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: M20 [Meitner USB Audio 2.0], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Steve
Hi Steve,
Ok looks like its assigned to card 1 correctly.
What is output from the following cmds:
1) cat /proc/asound/card0/id
2) cat /proc/asound/card1/id
3) amixer -c 1
Regards,
Tim
Tim,
I am having issues similar to Jerms. Long hangups and stuff just doesn't work like it should. I think my earlier problem with the i2s not being available in the settings is one example. Another is the problem shown below, I selected 24 bit but it is resampling to 32. Earlier it was working fine, I was doing some experimenting with the sample rates (which almost always leads to having to unplug the Pi as it hangs on the MPD reboot) and when I moved it back to 192/24 it selects 192/32. Both windows and android chrome were used, android seems to be quite a bit worse.
It is bad enough in the usability department that I am going back to 2.5 and a Pi 2 (which were pretty rock solid for me) for the time being.
Very odd. The symptoms suggest either a bad sd card or network issues, something external to Moode software.
I would run a 30 sec ping test from Pi to your router and then examine the ping stats for %packet loss, long round trip times, dropped packets, etc.
This post provides a bit of info on how MPD and ALSA handle bit-depth.
http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-268.html#post4695445
-Tim
Hi Steve,
3) amixer -c 1
Regards,
Tim
Hi Tim,
Output below;-
pi@moode:~ $ cat /proc/asound/card0/id
ALSA
pi@moode:~ $ cat /proc/asound/card1/id
M20
pi@moode:~ $ amixer -c 1
amixer: Mixer hw:1 load error: Protocol error
Many thanks
Steve
Hey Tim...
Using 2.6 TR2 and everything works great, and thanks for adding the file playback info below the artwork window!
Still getting clicks on 24/96k+ files - setting re-sample to 48k fixes this. I get the same thing on all Pi3 MPD players I've tried, so it's probably not a Moode thing.
Feature request: very minor, but it would be nice to have a Refresh button on the top bar. Maybe a Moode logo in the upper left that would refresh the player if clicked...? Just a thought.
Hi Tim,
Output below;-
ALSA
M20
Many thanks
Steve
Hi Steve,
The error indicates that ALSA is not able to successfully read the DAC's device descriptor and load its mixer control information. I did a bit of searching and found a couple of references for the error but nothing in terms of a fix or bug report.
Regards,
Tim
Here's a strange one.
Headless Pi Zero with non-AP wifi dongle.
Flashed 2.6 TR2 and created moodecfg.txt with wifi ssid and password.
Booted up ok onto the network using DHCP but from the pi, it is unable to resolve DNS.
Any clues?
Hi Phil,
Try these cmds to show the addresses that DHCP configured for name server and gateway on the Pi.
cat /etc/resolv.conf
ip route show
-Tim
Some excellent Classical stations (plus Jazz) added to Moode 2.6 courtesy of diyAudio member TheOldPresbyope. Thx Kent 🙂
WBJC Baltimore - Classical
WCLV Cleveland - Classical
WCRB Boston - Classical
WFMT Chicago - Classical
WQED Pittsburgh - Classical
WRTI Philadelphia - Classical
WRTI Philadelphia - Jazz
-Tim
How come when I enable shuffle, it just plays the same songs out of a much bigger list?
Even if restarted and re-shuffled the same songs play.
I'm testing a solution named 'ashuffle' that appears to work nicely, at least from the cmd line. It might be a possible to integrate something like this.
Automatic shuffle
https://github.com/Joshkunz/ashuffle
I'm using it in its second mode where it continuously adds a random track to the end of the Playlist after the last track ends. If consume mode is turned on then you get random play without the Playlist growing. Interesting.
Regards,
Tim
Are you planning to update to mpd 0.19.15 from my understanding this update
master/mpd.git -
has enabled hls support
https://forum.musicpd.org/viewtopic.php?f=11&t=3748#p5809
Also i am experiencing a bug with current stable moodeaudio.
I am having a poor internet connection and when i am playing a radio if internet is too slow and the music stalls because of the stream. moode keeps displaying the radio playing by updating the time and after that it is impossible to add a song or clear the playlist.
resolv.conf was empty. No idea why.
I've just replicated this on another SD card with a Pi Zero and USB Wifi.
Flash Moode 2.6 TR2 onto SD card.
Create moodecfg.txt as per documentation with correct ssid and password.
Boot the Pi and it comes up, gets the IP address from DHCP server, but there are no entries in resolv.conf and DNS resolution from the Pi Zero fails.
Easily fixed by manually setting the wireless adapter's IP address as static from Moode's network config page, then setting it back to DHCP.
Phil
