Monsoon planars
music soothes the savage beast
Joined 2004
This is fr response from 0 degree on axis and 10, 20, 30 and 40 degree of axis.
Then on axis with phase, looks ok.
And finally distortion.
MH-700 like other planars has rising response from ~250 Hz up, with hump at 7kHz. There is some resonance at the hump, even spike in distortion.
I remember the tall versions at CES in Vegas but they were being played out on the main noisy floor area
and refreshingly clean and nice sounding despite those conditions
It would be interesting to hear how they stack up now
regards
David
Main reason for two tweeters is impedance, I do not like 4 ohm speakers. Now its all 8 ohm.
All glued together. Now to the crossover. I am thinking 5kHz. Mainly because I want to suppress that 7kHz bump on mid, plus it will relieve tweeter from overexcursion. It may be capable 1.5kHz, but why push it.
Started working on the crossover. Just 4uF for the tweeters, and 0.25mH for mid planars. 5kHz first order. Thats what i normally prefer if drivers behave. I try flat response and phase.
Measured response when tweeter and mid were wired in the same polarity (blue) and oposite polarity (brown).
Cleary cap is swithing in first order, tweeter needs to be flipped.
