• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Modulus-86: Composite amplifier achieving <0.0004 % THD+N.
How much lower will the noise floor be?
About 30 uV (unweighted). A bit over 20 uV (A-weighted).
I ask the question because the residual noise of the MOD86 is what has been holding me back from trying it on my compression driver (nc400 has a 25uV unweighted spec, which is already audible on my compression drivers with input shorted).
I suppose the audibility depends on the shape of the noise spectrum. It may be worth comparing the A-weighted numbers rather than the unweighted numbers. The noise of the MOD86 is basically flat with a very, very slight 1/f component.
Regarding gain, will it be easy to adjust to a lower value? How much will it reduce residual noise (internal noise, input shorted)?
You can get down to 10x (20 dB). I don't recall there being a noise advantage of doing so, though, it probably makes an improvement at the system level as the SNR from your source can be higher.
With the MOD86 you can lower the gain further by choosing a THAT1203 or THAT1206 for the front end. The MOD286 does not have this option.
As Andrew points to, a headphone amp might be the ticket. I'm working on such an amp and expect the noise to be really, really hard to measure. Single-digit uV (unweighted) for sure. THD well below that of the MOD86 (which is already world class). Drawback: 500 mA max output current per channel.
Expect more info on this to emerge at the end of this month. I plan to have it ready for the Head-Fi meet in Calgary on the 25th.
Tom
have a look at the lme49600 datasheet.
The datasheet shows the opamp+buffer. What about replacing the 49600 with a diamond driver + ClassA biased EF output. There are probably Threads with this topology.
I call that topology "opamp with big shoes". It can certainly be done.
Potentially you are in the 0.3ppm distortion and noise is ultra low using a modern low noise low distortion opamp like the lme49990.
Except the LME49990 is obsolete. It was discontinued by TI last year.
BTW: With these extremely wide-band amps (LME49600: 180 MHz!) you really need to pay attention to the circuit so you don't inadvertently make a power oscillator. My 400 MHz oscilloscope and 2.9 GHz spectrum analyzer were very handy during the debugging of my headphone amp prototype. If the controlling opamp in the opamp + LME49600 circuit has any oddities in the open loop response it is also easy to have a circuit that'll work well at Cload = 0 pF and Cload = 10 nF but will oscillate at 100 pF < Cload < 10 nF. Given that headphone cables add some 30 pF/foot, the consequences of such an amp design are obvious. It is possible to compensate for this. Just be careful and keep your eyes open.
Tom
Don't be afraid of noise in the MOD-86. I just connected mine to my 100dB/W/M Unity horns and it is dead quiet, I mean head inside the horn - no sound - dead quiet. My system has never been this quiet before, despite running very high quality amplifiers and an optimised gain structure.
You won't regret this build.
Awesome. Thank you for sharing your experience.
I would be curious to know the residual noise of the 14dB gain version of the MOD86.
The noise of the MOD86 is dominated by the THAT1200. The THAT1206 is 1 dB quieter so if you switch to the THAT1206, the output noise should be ~1 dB lower as well (back of envelope math, usual disclaimers apply).
Tom
500 mA, peak. Not 500 mA RMS. So 500 mW into 4 Ω, 1 W into 8 Ω. More relevantly: 3 W into 20 Ω (current limited), 3 W into 32 Ω (voltage limited). Just shy of 400 mW into 300 Ω (voltage limited).
Plenty for a high-efficiency driver and more than enough to launch your headphones into space. Yet, some will want 5-10 W to drive their headphones.
Tom
I want to use a 4 ohm compression driver that is very sensitive (JBL 2435HPL). The mass break point frequency is very high so it is very sensitive up to at less 6kHz, even on a constant directive waveguide.
I'm not sure how sensitive the JBL 2435HPL is, but my B&C DE25-8 is a touch under 110dB/W/M. One big difference in my system (WRT noise) is the passive crossover between the amp and the compression driver. This reduces mid band noise by ~10dB. Have you thought of implementing your CD compensation passively? This will improve your noise floor by around 10dB where your ears are most sensitive. The rest of the crossover function could be done actively.
The output stage has 20 dB of gain. While I have found a couple of ways to reduce the gain in the circuit simulator, none of the ways translated into good performance across the various oddities and corner cases on the LM3886. I can put an attenuator in front, but that defeats the purpose of the whole gain structure optimization.
Most people actually request higher gain (which is possible by swapping out a resistor).
Tom
I would like to avoid it if possible.
I still use a protection cap though.
In my JBL M2 clones I use the stock passive network that applies a ~9dB lpad and 1kHz 1st order filter to complement the active setting.
In this configuration, and with a 32 ohm compression driver, I cannot hear any noise coming from the nc400.
But still, that is a big waste of power burned into resistors: I'd rather use a dead quiet 10W amp than a "noisy" (all things relative...) 100W amp with a 10dB lpad.
Tom,
Will the MOD286 have differential inputs as well? You noted the different THAT input module options for MOD86 but that it wouldn't be an option for MOD286. Don't know if that means no differential inputs or just a different differential (would that be Diff-squared?) for MOD286.
That's understandable. How much power would you need? 10-15 W @ 8 Ω?
That is basically what the LPUHP would give me, but a tiny bit more power would not hurt, especially if I want something versatile that can also drive a high load and/or a less sensitive driver at times.
Can the other speakers achieve that 110dB at the listening seat?
Not that I really need it, but yes they can 🙂
I currently have nc400's and LPUHP, so I am pretty much covered, but I would love to have a more versatile amplifier that I can use in various scenario without searching for the perfect match for a given load and sensitivity every time.
Something as "silent" as the LPUHP, while being almost as powerful as the nc400.
Something like a THX AAA maybe ?
I'm not sure what you consider to be a "high load". The LPUHP provides 16 W (8 Ω). That's doable in Class A.
Free, of course. And available tomorrow, right? 🙂
Tom
