modify Pass Zen V9 as Headphone amp?
I've been listening to my amplifier for a while and I'd like to tweak it a bit.
With orthodynamic headphones I use the direct output of the amplifier and I think it's perfect. : D: D
I have configured a second output with a 100R in series but with high sensitivity headphones I can hear the floor noise.
I was thinking of adding a second resistance in series to 100 Ohm but I´m not sure if it´s right. Please, Would you recommend something?
This is the current scheme:
In the original F2J you will note C4 is 15,000 uF and is not conected directly to the 24v supply but through that bank of 4 .33ohm resistors. I would be tempted to try that first or even use a mosfet voltage regulator like was done in Zen9 .
Thanks 😉
I would like to clarify before that I am using ground as common instead of B +
I don't know if adding capacitance at the output will get better results, however it is easy to check.
About C4, I think that you mean that C3 instead of C4. Well in my amp, C3 is connected to ground through 300R. F2j has 15,6R (three 47R in parallel) in this place. I checked this before and with a low value here, the amplifier has very little power and a large offset.
I think other two options:
A) Use B+ as a return/common instead of ground although I recognize that I don't feel very comfortable with this because I didn't have good results last time (offset)
B) Use the filter section of Zen 9 although this is supposed to change transformer for another of about 20vAC.
I need to play a little with the multisim for check.
