MMats D700.1
I only changed these 3 nichicon caps from 4700uf to 5600uf caps.
So with no audio input in there should be no triangle waveform on pin 7. So is possible that the opamp lm837 is bad.
FYI, The 10 turn POT is for current overload threshold. Same for the Earthquake. You should leave it where it is. Check the 2.2ohm 3w resistor behind the cap and make sure it's in tolerance. It likes to open up when the amp is clipped hard.
Do you have the correct setting for the pot's output to the comparator (to avoid having to do additional trial and error testing to get an acceptable trip point)?
Negative. I avoid fooling with it. Last time I did one I turned it all the way off. I then drove the amp hard into it's advertised minimum load and turned it up until trip. Then I dialed it back 1 turn. I halved the load and it tripped. Hardly scientific but seemed sufficient. I should probably take better notes about these thing!
I took notes for 20 of the 30 years I worked and it wasn't enough.
The way you did it will work. You could also measure (accurately) the shunt resistor value and use the rail voltage across the lowest rated load (giving current at full power) to get a voltage across the shunt at full power. Then use that to set the comparator trip point.
1. That 2.2 ohm resistor behind the no polar cap reads 2.4ohm
2. As for the current protection not sure if it’s set correctly but will tackle that once I can get a clean audio waveform after cranking the gain up, he. When the audio starts to breakup you. A start to hear the high frequency coming from the board. I have tried changing every ic on the board and wiggled every component and no change on the distortion of the wavforme
I own a bunch of the amps from this series. This one is essentially a de-scaled version of the D300/200/100HC. The Earthquake 200DHC Schematic is similar, just not spot on. The Bipolar cap needs to meet or exceed the rail voltage in it's power rating. Make sure that it does. I cannot recall how muting was handled on these but check the small number of to-92 transistors on the board for a j-fet. Might check that for audio signal to confirm. I'm sorry I cannot be of more help. I have one here on the 'someday shelf' with the same symptoms so i'm watching with interest. Seems to be a lot of threads with 4080 amps and a similar issue that were never resolved. user @rdiaz has a lot of notes on these amplifiers and may be able to help as well. Good luck!
So for the time being I was able to install 2 polarized caps in series just for testing, that did clean up my waveform.
Unfortunately, I still have some scratchy frequency from the subwoofer when connected with no Audio playing. There is still around 0.5vdc across speaker terminals when volume down
