Minima SE Class A amplifier - help please
Guys... hê-hê... again today I sat down and stared at the tangle of wires and remembered something I read about Darlington step being good for high gain and drive...
I tried it! I made a Darlington pair with the 3055 at the final and a MJE4919 - input drive is done by a BC560.
Sound is fairly neutral and gain is massive! Had some oscillation issues but sorted that with a cap and resistor here and there.
D
GlidingDutchman said:
Okay - this time I will laugh!! Ha-ha! There you go...
Uhm... what about the text goodies?
I am blind in this electronics world you know... ???
We all have to learn from start --- when comes to new things, like design with transistors & whatever.
Even once Nelson Pass was a 'newbie', a learner.
Now, if anyone want to learn, some what is there to learn and see
about TurnTables and Super Vinyl reproductions:
😎 Go visit GlidingDutchman website, Pleeease!
It is simply one of the best turntable sites I have ever seen on the web 🙂
Lot's of intresting Images of state-of-the-art Phono DIY homebuilt constructions.
Very good & a visit recommended to any Really Audio interested.
http://www.theanalogdept.com/
Lineup 🙂 best greetings to GlidingDutchman & thanks for your website
One Example: Good Azimuth alignment
Uhmm - much obliged... yup, that is me!
and my system (more or less)
My latest turntable - the DEWAUDIO Credence - see attachment
D
Dank u voor uw bijdrage - ik waardeer het werkelijk. Nu kunnen wij deze ontwerpen bespreken!
Thank you Tschrama!
I am glad you see the design goal here and contribute by supplimenting the circuits.
Last night whilst testing I noticed the circuit picks up AM broadcasts... is this natural? How can it be damped?
D
This scheme works the best! Very good overall response and good drive. Noise is very low and so is the destortions.
I would like to build a neat little headphone amp with it. Any others game?
tschrama .. is a good designer.
He has experience needed, to build simple & good.
(Most anybody can do complicated & advanced amplifiers that are 'good'.
It takes a true Amplifier/Transistor understanding, to keep it very simple & still good)
Gliding, hope Holland will do well against Frankreich, tonight. Holland 'crushed' the Italy with 3-0. Super! My own Sweden will have a hard time with Spain. Tomorrow.
I will see, if I can dig up some old and simple stuff.
I remember an old thread, about Very Simple 2 stage designs.
Even Nelson posted his variant 😎
Regars, Lineup
edit:
Think it was this topic from 2002, by a netherlaender!
Simplest amplifier possible with BJT's
And This was Nelson Pass first suggestion:
http://www.diyaudio.com/forums/showthread.php?postid=51917#post51917
HIS CIRCUIT schematic, see my attachment
hi.
there are 3 connections to any amplifier
1. Source. signal input
2. Supply. power energy input
3. Load. Signal output to Load
We can say 'an amplifier' is an adapter between input Source & Load.
An adapter that will amplify input signal and adjust it to Load requirements.
CD-player output ->>> Speakers 8 Ohm
wont work, you know
When setting up an amplifer, we need good info about those 3.
Source.
Cd-players, normally, would want at least 10 kOhm - 22 kOhm load to work into.
( 8 Ohm or 55 Ohm, AKG K 240 MK II, will need too much current for CD output )
This is why we need an adapter. A headphone amplifier.
I think I have what I need.
I be back with my circuit suggestion.
I will use mkax 3T or max 4T design. (max 4 transistors)
🙂 Information of The Three factors. 🙂
1. You will feed from a CD player.
Input impedance, resistor, needs to be like 10-22 kOhm.
2. Power input = 12 Volt DC lead acid battery.
Good if amplifier does not take excessive currents = empty your battery in a few hours 😀
Battery has a good feature. Has got no 50 Hertz hum problems.
It is clean and good power, without a lot of filtering electrolytic Capacitors.
3. Output. LOAD = 2x 55 Ohm AKG headphones.
The sound pressure produced (sensitivity) is:
91 dB SPL per 1 milliWatt,
(or +104 dB/ 1 Volt rms input)
4. Output devices. One or two 2N3055 power transistors.
AKG K 240 MK II
http://www.akg.com/site/products/powerslave,id,1063,pid,1063,nodeid,2,_language,EN,view,specs.html
Type semi-open, dynamic headphones
Sensitivity 91 dB/mW, 104 dB/V
Frequency range 15 to 25,000 Hz
Rated impedance 55 ohms
Max. input power 200 mW
Hi Lineup
I have the AKG K240 pro edition which is 600 ohm as well as a set of K141 edition also 600 ohm.
They work well on the circuit as adjusted by Tschrama.
I use an EAR 834P phono-stage (12AX7 tubes) for the phono section.
Will probably run the headphone amp from the main amp's tape outputs.
D
PS - Holland's football team's got my support! :nod:
Hi Lineup
How much current drive output max, can mains tape output
or any other source you want to use, e.g. tube preamp output, provide.
Tube preamps, as far as I know, likes a bit higher impedances connected.
Say maybe 100 kOhms.
So, if I am correct in this, then is good if headphone amp should have input impedance 100 kOhm.
Will take most anything: tape out, tube preamp, cd-player.
If your headphones have Load impedance = 600 Ohm,
then we might need at least Voltage Gain ~ x4 - x8.
On the other hand, the good side, 600 Ohm will take/need like 10 times less current!
1 Volt / 600 Ohm = 1.667 mA
1 Volt / 55 Ohm = 18.16 mA
