My Mini-As are running good
Here is the new SMD Mini-A layout that I am working on. It is based of the through-hole one, and accepts balanced inputs:
The board is just a bit smaller than the TH version, and the SMD resistors mount on both sides of the pcb. The resistor designations are the same as from the TH version:
http://www.diyamps.com/aleph/
Here is the through-hole board for comparison:
Brian
Brian
Banned
Joined 2002
Banned
Joined 2002
Re: HAHA.
Why not. their tolerance is lower.!
xr000 said:IT 'S EXCELLENT
But I don't like SMD.conponent.
surport!
Re: Re: HAHA.
I like thru hole better too.
1) more choices and can source locally if necessary.
2) easier to work with.
c) I already have a bunch of thru hole stuff on hand
4) easier to work with
Brian's previous thru hole mini/30 boards left very little to be desired.
Why not. their tolerance is lower.! [/B]
Banned
Joined 2002
Re: Re: Re: HAHA.
1st) thats Mine & Brian's Boards, i helped.
2nd) the mini a SMD can be sourced out all from digi key all parts are from digi key.
3rd smd mini a's sound better.
When i get a board made ill build a pair and pass them around any one interested in listening to a set.
The first smd Mini A's ( the ones that got all this going ) Sound better to me than the through hole one's.
BrianGT said:My Mini-As are running good
Brian
If you want to have the smallest board possible you could ditch the SMD 9610s and go back to through hole, just for the 9610s, and have better heat dissapation options. But don't listen to me, I'm not currently in the market for boards.
I still envy your board deisgn skills.
Banned
Joined 2002
needtubes said:Will the new through-hole mini-A board run include the extra output boards to allow expansion to Aleph3/30/5?
They are the same as the last one's We have not changed any thing with those.
________
Jase
Sorry man, I didn't know..nice job! I could only dream of developing a design with my current skills in this area.
I'm not in the market for boards right now either. Feel free to ignore me!
Banned
Joined 2002
No need to ignore you.! keep posting if you have ideas please post those too Every ones input helps. Thus how we got this far with this design.
Jase
Banned
Joined 2002
MashBill said:Jase,
Are you doing parts kits too?
Thanks,
Bill
Yes for both psu's and both smd / through hole MINI A's.
Re: Re: Re: Re: HAHA.
You didn't help with the board design... just with the organization of group buy for the component kits.
Brian
jleaman said:1st) thats Mine & Brian's Boards, i helped.
[/B]
Brian
- Group Buys
- Mini A Board Run
