microzyma,
AS far as your noises - double check the output switches on the far left side of the board. I must admit I had mine set wrong to begin with and had those noises, too. AS soon as the music began all was fine. Check the manula but I think I remember if you are using PCM mode only, as I am, both switches should be OFF which is both of the toggles to the left.
Name a good LINUX based ripping program.
You must consider how silly and childish it looks when you have to resort to attempts at personal attack whenever someone disagrees with you. I do have to point out that you are the one who stated that you are not a computer guy. I happen to be one - with 35 years of experience with customized, embedded systems as well as computer audio. Not that it proves anything, but you might be a bit more careful before making assumptions and allegations about things you don't know anything about.You must consider how absurd it looks to comment on things of which you know very little and seem to have even less desire to learn about.
But why use dBpoweramp in the first place?WINDOWS is used because that is what dBpoweramp requires.
Which one was that, and what was wrong with the other ones?I have tried many of the LINUX based rippers. The only one that is any good requires the title you want to copy to be in a very small database which makes it useless for general purpose use.
All the ones listed allow you to enter the information manually if you don't want to use an internet connection.To expand, it would also require connection to the internet so it could see whether or not the title is in the database which would then allow a rip to be made.
That is your choice - but you don't have to, of course.I do not want any audio computer to be connected to the internet, ever.
Linux is much more modular and flexible, so much easier to tailor (which is why it is used in all the embedded devices and commercial music players). If you put in as much effort in tailoring Linux as you did with XP, you end up with a much smaller, more efficient result.Believe me, when you get XP to this size LINUX is cumbersome in comparison. There is nothing wrong with the basics of XP. It is when you try to make it do everything for everyone that one runs into problems with audio applications. If you tailor it for your purpose it is as good as we can get at this time.
Indeed. It's just that most developers and vendors have concluded that Linux is a better solution for a customized or embedded music solution.Another case where there is no universal answer. Is there ever a case where there is a good universal answer? Not in my experience
is there a stateside source for pps caps?
I would be willing to bet Julf has never touched an SDTrans much less owns one.
Doesn't seem likely, at least not to my questions.So, will an answer be forthcoming?
"not as good" in what way? And I really didn't realize ease of use was a priority for you, if you are willing to accept having to type in all metadata by hand (or do without any metadata such as artist, album and track name etc.). But sure, we all have different priorities.I have tried the LINUX rippers mentioned and did not find them to be as good, nor anywhere as easy to use, as dBpoweramp.
Morituri. Mainly because it is written in Python and easy to modify as needed (and it works well from scripts that allow me to automate the ripping).So which one does Julf use?
You can remove processes and drivers, but the kernel, windowing and user interface are all a huge monolithic blob. The advantage of Linux is that everything is modular - if you don't need a graphical user interface, for example, you can easily leave it out completely.XP is modular, too, though I am sure in a different way. Plenty of tools out there that I have learned to use so I will stick with XP until there is reason to go elsewhere. For this purpose.
What do you want me to try? And all I wrote was "I guess there is a reason why most dedicated players are Linux-based and not Windows-based", in response to your posting about all the hassles with Windows. I don't care if you try something or not - just wanted other people to know that there is an easier way.You are always wanting me to try things yet you seem to have no intention of trying anything anyone else suggests. A little unbalanced?
I do not answer your questions since they have little to do with what my post was about.
Nothing would grant you more credibility than a project you are involved in that has brought a little extra measure of enjoyment to a few folks' audio systems. If you have done this I apologize for missing it.
Plenty of folks make these. WIMA has a good selection of them that you can get at MOUSER and DIGIKEY.
Why do you want to use them? Do you have space limitations where you intend to use them? I thought that was their only advantage. Never thought of them as particularly good for audio - unless this is a surface mount application and they might be one of the better choices for that.
Lord, how can I keep from singing?kumbaya, my lord...
Save your money on caps and get some of these batteries. They are a marriage made in heaven for digital electronics. Their current delivery is instantaneous and abundant.
Plus, like a shunt regulator (and even better) is their ability to sink junk from the circuit.
