Memphis St-16 500D
This board I have circled in yellow and this isn't my amp I found a pic online of the same one
Im wondering if I could swap out the same card I have laying around in my 1000d that works to see if itll work I cant seem to figure it out I tested the components on the board they all appear to be in working order just not the ic's I couldn't test
Thanks Perry I went ahead and swapped the boards with a known working board in which it did the same thing I went through retesting the 4 power fets I didn't replace and one gave a weird reading so I went ahead and swapped out the irf9640 with new powered the amp back up again the amp passes the protect test the green light lights up like it should but when I went to test the amp for sound with a speaker hooked up there is sound but very little and theres a popping sound coming from the speaker and the green led dims everytime when it pops ive replaced all irf3205fet bjt 140's the 2 irf640's and now all irf9640's and still something isn't right
