Memphis St-16 500D
I went ahead and swapped the output board you mentioned cold amp it wasn't popping but by the time I started playing music it started popping again I also notice the red light flashing and the green power light was dimming so while I had the 1000 apart I went ahead put the board out of the 500 into the 1000 I know works and no change it didn't seem to have any loss of sound compared to the 1000's working board and no popping in the 1000
its auto ranging and they were in the amp at the time im wondering if I should have not put silicone on the rectifiers near the temp sensor also maybe I don't have enough kryptonite on the heat sink that the insulator board was badly burned I only used one sheet
leakage as in like a short circuit when check cont.
Kryptonite as in the orange plastic looking material you recommended me getting awhile back beings the material (looks like cardboard almost for the insulator) attached to the heat sink rails where there badly burned I put the material between the heat sink rail where it comes in contact with the fets
Kapton
The cardboard dissipates the pressure so that the transistor lays flat on the sink. It's not an insulator. Cardboard can also be used to compensate for different heights between adjacent components.
You cannot check for leakage with the meter on anything other than resistance. If the meter is set correctly, it should change from OL to something in the mega-ohms when you touch the metal part of the probes with your fingers.
A short could also be considered leakage but leakage isn't a short that generally will show up with the meter set to diode-check or continuity.
Ok thanks for the information perry I wasn't aware of that is there something I could use then for the heat sink rail for compression are you saying I can use a flat piece of cardboard all the way acrossed the rail to fix the burned up cardboard material?
