Matching transistors & measuring the results
Joined 2020
I think I have managed to source a couple of bipolar supplies. One is a +/- 9V 2.7A supply and the other is a +/-12V 2.0A supply. These look like they should work. Leaning towards the 12V supply as it operates at lower A and I am thinking that it is easier to drop V a bit if necessary, rather than trying to increase the V. Cheap enough that it saves me the hassle of sourcing parts and assembling. Any comments on which of the above supplies would be better suited for use with the transistor matcher?
Can you share a link to the 12v PSU you found? Thanks!
