MarkAudio MAOP11 + SDDBH-T13.5R-AD (Dual Back-loaded Horn adding adjustable Duct, no sound absorber)
Standing waves are not a concern for this box.
Given it is an ML-Voigt, standing waves ar significant. With no damping the only lowpass filters will be the restricted terminus, the driver offset, and a little bit from the expansion of the line at the fold.
The bass extension comes from utilizing the primary standing wave, but all the harmonics will cause ripple. How much ripple can the listener live with? This question is complicated by the room.
I would be at least lining the box, if not adding a bunch of well teased polystuff.
dave
Reactions: nandappe
Hello,
One last question before I started making my SDDBH T13.5 manufacturing
The two outputs are adjustable.
Can you tell me what are the distances between 7 and 27 and between 29 and 22, the usual distances from which have the adjustments in addition and less ?
Thank you.
Duct size can be adjusted to your preference.
Hello everyone
I have just finished building a SDDBH-T13.5 type speaker with a Markaudio MOAP-11.2.
I compared it to my current 3-way speakers, custom-made by specialists on a French forum.
The SDDBHs do not bear comparison at all.
Of course, the manufacturing cost is not comparable either. (x 10)
With or without damping, and despite all attempts at output adjustments, the treble is very recessed and confused, the bass is also very recessed and blurred and the midrange is put forward, while remaining blocked in the speaker, it doesn't fill the room.
It's an interesting experience but I won't keep this speaker and I'm reassured that a well-built 3-way speaker offers the best sound across the entire audible range.
Hello everyone
Alren, I am sorry to hear about the results.
I've been uploading videos to YouTube to stop people from making enclosures they don't like, but it doesn't seem to have helped.
This box is complicated and it's easy to make assembly mistakes.
Do you have any photos of the inside, a frequency response graph, and an impedance response graph?
Alren
It doesn't feel quite fair to compare a 3-way for 10 times more expensive cost and a full range driver.
I'm not sure that a full range driver that costs 10 times more can give a better sound that beats your 3-way speaker.
Would be fun to compare a more expensive full range driver.
There are many drivers that are more expensive.
You need to play at least 50 hours and up to 200 hours to give a statement about the sound quality. Everything needs to be softened to give maximum sound.
It is true that the running-in only lasted an hour. I will continue a little longer.
Nevertheless, the difference is really significant.
No, I did not take a photo during the assembly but I followed the plan to the letter.
It is, in fact, not very fair to compare this wideband with a much more expensive three-way speaker.
But this three-way is in my living room, and the comparison is easy.
About fifteen years ago, I had built a speaker with a Fostex E sigma 208 and a T90 for the treble. My memory was good for male and female voices but it already lacked bass. This speaker had already been replaced by a better three-way.
Nothing serious, it is an experience.
They need about 100 hours of gentle break-in. If it essential to best performance and they will change, sometimes quite dramatically, in that space of time.
Once you get thru that you can start turning things up. If that first hour was not gentle you could well have imposed some meemory into the suspension (spider) and they will not reach peak sonics if that is the case.
Put them face-to-fave out of phase, throw a nblanket over them and feed them FM for a week.
dave
Reactions: LeifB60
I can only confirm that my maop 11.2 improved significantly over time. Difficult to say they have 300 or 400 hours at this time. For sure I break in for first 90 hrs at very low level as advised.
The story of 3 ways vs fullrange is a fundamental personal choice combined with the type of music of choice. In my 40 years of audio experience I moved 3 times back and forth between 3 ways to fullrange and always land to fullrange.
True I mainly listen to Portuguese fado , i.e. acoustic guitar vocals or small ECM ethereal jazz. In that landfill I personally think, fullrange dominate. Cheers
Reactions: LeifB60 and wchang
Hello everyone.
I made this SDDBH-T13.5 speaker with a MAOP11-2.
The result was not good at all: brilliance, resonance, frequencies too forward, others erased.
As you advised me, I made it work for more than 100 hours.
The result was always the same.
I abandoned this project.
I talked about it with a friend, a recognized specialist in speaker tuning.
He suggested that I develop a bass reflex speaker with this MAOP11-2.
In the end, I have a small 15-liter column speaker that sounds very good. I am very satisfied with it.
The treble response is attenuated by the room.
Look at the orange frequency curve which is the "in room" curve
It is made for a small room and listening to it at 2m or 2.5m.
The efficiency is not very high, but this speaker is not made to provide sound for a performance hall.
Reactions: nandappe
