Re: Re: transformer output
Thanks Andy, will try.
Would these Sowter 3575 do any better?
Kind regards,
Jaap
poynton said:
HI.
these are possibly not the best Txs to try - too many windings on the primary !
But if you want to try,
wire the primaries in series / parallel to give a centre tapped winding - centre tap to ground / hot ends to the DAC outputs
wire the secondaries in series - try straight to the amp via a 50k volume control [ the Tx must see a high impedance ]
Andy
Kind regards,
Jaap
Not really... you need a centre tap primary and a single secondary with ratio 1+1 : 2 [or more]
http://cgi.ebay.ie/Audio-Transforme...5QQcmdZViewItem
http://www.farnell.com/datasheets/9126.pdf
Andy
Andy
Evening modders,
I did a couple more minor mods yesterday and have been listening today for hours.
The mods:
Added the two remaining grounds to my star point that I'd missed previously, and connected the star to the IEC socket.
Changed output resistors from 100R/1/4w metal film to 33R 1/2w carbon film.
Changed CD04, CD07, CD15, CD16, (DAC) C510, C511 (decoder) from 47uF and 220uF/10v to 4700uF/6.3v Pana FC.
The sound:
More 'analogue': bigger, more controlled and detailed. Dynamics improved too: it seems there's a clearly lower noise floor.
I'm very happy - cheap upgrades for a good effect![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(display still dead
The mods:
The sound:
(display still dead
![dead :dead: :dead:](https://files.diyaudio.com/forums/images/smilies/dead.gif)
Gooch said:Hi everyone
The headphone circuit is disabled by removing C901 and C902.
So can I safely remove C903 & C904, Q901 and the surrounding components? I was looking at that space to mount my clock card.
Dave
Hi Dave,
Yes you can, but did you disable the +/-12V too?
In a CD63 that's U271/272.
Ray.
Hi gy21,
http://nl.farnell.com/jsp/home/homepage.jsp for Panasonic FC and Rubycon ZA/ZL/ZLH
http://www.degroefaudio.nl/dg_componenten.php for Black Gate
http://www.percyaudio.com/ for Nichicon and Black Gate (USA)
Ray.
Ray.
Bigger caps?
There have been several posts about using huge electrolytic caps for decoupling DAC, decoder etc. and I started questioning its adequacy.
I would expect that you start drawing large current from the 7805 regulator when you start it up, but this one is hopefully short-circuit tollerant and will recover. In the same time there is huge cap on the input, so the input and the output voltage will probably track each other until the final voltage at the output is reached.
However, I don't understand why do you want to use 4700uF/6.3V capacitor for the DAC drawing approximately 2+3+35=40mA current? I don't have the numbers for the decoder. You can probably use it with the same success on a switched-mode power supply giving 5V and several Amperes...
You can never put that huge capacitor directly across the supply pins of the DAC; so you will always have the impedance of the interconnects deterioriating your HF performance. I think it is much better if you use modest electrolytic on CD04/05 and then do the decoupling with 100n X7R 0805 or even 0603 SMD right on the chip pins or even putting several caps with different values in parallel. These ceramics or maybe PPS foil have a very low ESR and ESL, so when they are put in parallel with the electrolytics they will always give lower equivalent resistance and better wide bandwidth effectiveness (like when the ESR and ESL of the electrolytic start deterioriating the cap performance, the ceramic cap will take over and extend its effectiveness into higher frequencies).
Re: Bigger caps?
I think you misread. I was talking about C803/804 (3300uF) and C813/C815 (4700uF) in the power supply department.
Anyway i'm mainly follwing the tnt mods and 6h5c document on modding the cd67.
ratep2001 said:There have been several posts about using huge electrolytic caps for decoupling DAC, decoder etc. and I started questioning its adequacy.
gy21 said:If you increase C803/804 (3300uF) and C813/C815 (4700uF) for higher values caps is there a risk that the other components cannot handle these?
I mean I don't want to blow up anything![]()
Hi gy21,
You can safely increase those if you like
![yes :yes: :yes:](https://files.diyaudio.com/forums/images/smilies/yes.gif)
![clown :clown: :clown:](https://files.diyaudio.com/forums/images/smilies/clown.gif)
Ray.
Re: Bigger caps?
Hi ratep2001,
I agree, a small cap can perform better than a big one. Big ones have more parasitic inductance because of their construction. For the amount of current it is certainly not nescessary.
Ray.
ratep2001 said:You can never put that huge capacitor directly across the supply pins of the DAC; so you will always have the impedance of the interconnects deterioriating your HF performance. I think it is much better if you use modest electrolytic on CD04/05 and then do the decoupling with 100n X7R 0805 or even 0603 SMD right on the chip pins or even putting several caps with different values in parallel. These ceramics or maybe PPS foil have a very low ESR and ESL, so when they are put in parallel with the electrolytics they will always give lower equivalent resistance and better wide bandwidth effectiveness (like when the ESR and ESL of the electrolytic start deterioriating the cap performance, the ceramic cap will take over and extend its effectiveness into higher frequencies).
Hi ratep2001,
Ray.
6h5c said:
Hi gy21,
You can safely increase those if you like. There's no fire-hazard
Ray.
Hi.
Ray , are you sure? I have heard that some CD Players have a tendency to spontaneous combustion !
The size and type of capacitor after the regulator is a matter of some debate.
Some say that a large cap. does not allow the regulator to react fast enough.
Certainly some regulators do not like low ESR caps such as Oscons.
Also if the cap is large, a reverse diode must be used.
Andy
poynton said:
Hi.
Andy
Wich cap do you mean with the cap after the regulator? C813?
On my player I did not touch the regulators, so they are the default ones.
H.
I was talking generally.
In the '63, I would refer to C805, C806, C815.
Andy
gy21 said:C805, C806 i'm raising from 470u to 2200u
C813, C815 are almost kept the same, 4700uF, just low esr types (panasonic fc)
and C814, C803, C804 ?
C803, C804 yes
C814 does not exist in cd67se
I have a cd67se
Re: DAC clock
http://www.acoustica.org.uk/
Right in the middle. PFM Flea. Great powersupply for your Tent XO.
ratep2001 said:AVR300,
Where did you find the schematic for the DAC clock? Is ti a Colpitz?
I started searching down the posts, but after several pages it didn't make any sense to continue
P.
- Digital Source
- Marantz CD63 & CD67 mods list
