awpagan said:the 22mV noise?
you have problem with 20mHz scope
mine is a 5mHz velleman portable![]()
Hi Allan,
I'm afraid it's not the scope. The noise is coming out of the player....
Brent measured it too the other day.
Ray.
6h5c said:
Hi Allan,
Ray.
i didn't think it was the scope.
what frequency is it?
is there any harmonics relevent to it also.
allan
awpagan said:rowemeister
"""Now what do I do now...... """
give us the details of your present configuration
and we all will do our best to think of something![]()
allan
Do you want to know what I have done to my player?
err I have changed almost everything. lol
I am going to compile a full list of mods.
I have 10 regs (mainly Audiocom) so every rail is isolated, all caps and resistors on opamp , dac , servo , rf and hf circuits are 0.1% tol and silver mica. Nearly all my big caps are Black gate.
I have 3x nuvotmen tx as well has the marantz toroidal. All diodes are HexFred.
bypass caps on dac etc. Opamps are a combo of OPA627 and opa132 on browndog pcb.
coax mod
The output caps and HDAM is bypassed with silver wire. muting removed. etc etc
coax mod
Aaahhhhaaa!!
you have opamps still.
allan
awpagan said:i didn't think it was the scope.
allan
Oh, sorry...misunderstood your scope-joke
Too serious at work here, I think...
I tried triggering my scope to the various clock signals in the player, but I can't get a clearer picture. It's too wide-band. Probably HF-residue from the DAC's PWM outputs = lot's of harmonics.
I placed an extra 100p capacitor parallel to the 100p in the filter and that reduces it considerably, so I guess we'll need a higher order filter to get rid of it.
Ray.
Ray.
I'll see if i can find the info about the 44.1Hz noise.
may be lucky
yes harmonics, which are from data and which are from noise?
might have to put a very accuate filter after and then subtract the
known(filter).
allan
ps work does interfere with interesting stuff
philpoole said:Have you done any mechanical mods? I did mod a friends CD63 with lots of bitumen sheets. Not entirely sure if it helped the sound, but it did make it mechanically quieter. Made a near stock CDP over 5kg - so it could nudge yours into double figures
Phil
i havn't done much in the way of mod's yet. just starting
go back thought the thread and look at the pic's of rowemeister's
it looks awesome
and a far few mechanical mods too
allan
ps or wait for the sumory with pic's too
Ray.
Hi.
What about replacing the LC filter between the 2 op amps with an active filter?/
Andy
poynton said:
Hi.
Andy
or fet balanced stage
allan
Sorry Allan, I wasn't very clear.
I was thinking of ideas for Rowemeister's
It does look good doesn't it? I thought I recalled he might of padded out his transport slightly (might of imagined it, this is now a very long thread
), and I also recall he weighed it and it was a good weight, and adding to that is always worth it
I did also wonder once if there was any merit in mounting the transport and pcbs using rubber washers in an attempt damp vibrations. I think it would be a real 'scraping the barrel' mod, but I think Rowemeister has done nearly everything else!
BTW, I've modded a friends CD63 with both electronic and mechanical mods, but mine has simply had (more) electronic mods and sounds better IMO, so I wonder about the scope of mechanical mods, just suggesting them.
Allan, compared to Rowemeister's, my box is only part modded (Kwak clock, opamps, vregs for DAC, HDAM removed, capacitor upgrade, silver mica and 0.1% resistors on analogue filter, PSU diodes swapped for schottky etc) and I can wholeheartedly recommend modding to any level. My first mod was the opamp upgrade and removal of muting transistors and output caps. Even that impressed at the time, and I keep going back to my trusty Marantz for further tweaking.
Glad there is still work for me to do and improvements to be made. Half the fun is hearing how other's have progressed and planning what the next mod will be.
Phil
Phil
allan
A balanced stage , whether TUBE or fet, will only cancel "common mode noise" but noise is, by its very nature, random.
The LC notch filter is tuned ( I forget whether F or nxF ) and complements the filtering performed in the DAC and by the RC filter post-DAC.
This is the type of filter ( active ) found in BurrBrown data sheets. ( not that is necessarily 'good'.)
http://www.hagtech.com/notch.html
This gives nice results with 44k notch and 1000pF (Si-Mi) caps
Andy
Thanks for the praises everyone
I have done sound deadening on the chassis and used aluminium paste to bond the chassis to the extra plate (SE and KI) so there is no vibration. I put some deadening material under the strut bar and on the transport.
This mod improved bass and treble a little.
It weighs just under 7KG now lol
Phil you too have done some very good mods, keep it going![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
rowemeister said:Ray
Has you know I have the OPA627 and OPA132 set up.
What difference would an all OPA627 setup sound like?
Hi Brent,
A dual 627 setup doesn't sound bad of course, but I found it a bit too dark, too "brown" if you like. I think the 132 sounds more open compare to the 627. It still has the typical Burr-Brown sound many people talk about, but less of it.
At the moment my favorites are OPA627 or AD8610 after the DAC, with OPA132 or AD8510 in the filter.
Ray.
poynton said:Hi,
---The LC notch filter is tuned ( I forget whether F or nxF ) and complements the filtering performed in the DAC and by the RC filter post-DAC.---
Andy
Hi Andy,
You got me wondering why the notch filter is no longer present in the CD57/67 (the 1000pF and 220uH in the CD63). Maybe just a simple cost-reduction that no-one will hear.
It is supposed to be tuned to 8*Fs. I entered the whole Marantz filter in Micro Cap, and i'm going to do some more simulations to see if I can optimise it further. I want to improve the group-delay as mentioned on Pedja's site, and re-tune the notch filter closer to 8*Fs and see how that sounds.
Ray.
........ re-tune the notch filter closer to 8*Fs and see how that sounds.
Hi.
Not having diagrams for the 57/67 , I did not know that !
Are the post-dac components the same??
EDIT. Oh, yes. I have !!!!!
With only the 1000p cap and no inductor, it would roll off at 6db/octave (??) rather than notch? what would be the knee freq.? I can't compute - no software.
What effect would there be in adding an extra RC ( 10k/120pF ) stage in front of the first op amp?
Similarly, adding an extra 10K and 1000pF ( and for 57/67 an extra 220uH ) between the op-amps??
Andy
Fixing the 5v supply!
I finally got around to looking at the schematics for the CD63.
Seems Marantz slapped everything on one 5V reg, and added a 3300uf cap after the regulator.
Never used the optical out on the player, and looking at the schematics it's tied to that potentially noisy 5V rail!
What's the strategy for 'fixing' the 5v rail ?
Re: Fixing the 5v supply!
It's cheaper!
And so is everything else that uses 5v !
See Rowe's posts - the pictures sum it up !
Basically, split the analog sections off, power by extra transformers and more regulators.
And place an order for our custom transformer !
Andy
ash_dac said:Hi,
It's cheaper!
Andy
- Digital Source
- Marantz CD63 & CD67 mods list
