Marantz CD63 & CD67 mods list
6h5c said:
Hi Brent,
I don't know if silver will add anything there. It's mostly servo signals going though. I'd rather go for a shielded connection, like a piece of shielded ribbon. Maybe a separate coax for HF??
Any big sound-changes detected yet, with the blue LED's?
Ray.
Ray there is some little difference, I listened to it all last night with LEDs on. (switch being fitted today with cyan led's).
I will report with findings after weekend. I want to make sure I am right and not just believing it is better. If its worse I will say.
Everything sounded good last night though!!!!
I will get the wife to switch it on and off (without me knowing which position it is in) for the tests.
rowemeister said:
Yeah seen this. Got it book marked.
I may go for the coax soon but I want to use smaller wire.
Hi.
If you are replacing the ribbon, IMO the 2 crucial cables are the +5v supply and the HF signal. If you look at the routing, the +5v is at the end of a run with the uP also taking power - noisy!! Remember, most of the RF board is analog so this +5v should be from a clean source. Similarly, the routing of the HF signal leaves a lot to be desired and is a prime candidate for coax direct to R501. I suggested this earlier in the thread.
Andy
Hi Brent,
Cool, i'm curious about the results.
awpagan said:
I do like ray's earth point😀
allan
Thanks Allan, i'm flattered :blush: !
poynton said:
Hi.
Have I missed something or is it on the stuff Ray sent you?/
Andy
Hi Andy,
I scanned the PCB-layout of the CD57/67 PCB. If you want it I can send you a new CD57_67_doc.pdf, just give me a PM.
Ray.
separate analogue from digital
allan
allan
Hm, I wish it were that simple....
You would want to keep the top trace, cause that runs to the +/-12V groundpoint 😀.
All the local groundpoints are also connected through the top-layer groundplane. Not bad, but they should have designed a real double-sided PCB. That would have saved a lot of wire bridges. Maybe in the future i'm going to solder some litz wire across the board.
A virgin plain PCB, ready to be mounted 😀
(with Thorsten's circuit, that is)
Hmmmm top ground plain, dam forgot about that😱
o'well
looks like i'am going to have to take the pcb out again
this time just looking at ground planes. 😀
new pcb?
how about i2s out to separate dac etc
but this destroy's all the fun😀
allan
Quote:
Well, my mods have added 67% to sound quality, but my sound quality meter needs calibrating.
What were those mods if I may ask?
Well, my point is..I have seen fist fights develop over the sound of capacitors and if you blindfolded the same people they couldn't tell what the better sounding cap was.
I don't put a lot of blind faith into what people think they hear in the way of changes. Has anyone run any distortion tests to see if there was an improvement?
