Marantz CD63 & CD67 mods list
SimontY said:
Series resistors! Interesting way to go. No regs either - very interesting! I see most parts on the audio board are SMD. And it uses silver mica caps. I bet Ray's one is at least as good. But 600x more effort. Can't wait to listen!!
It uses discrete shunt regulation on the board itself. Better to have the regulation by the transistors. The whole thing is class A and shunt regulated, hence the PSU topology used.
Ray's one used shunt regs also, so I would expect it to be similar. His uses output coupling caps rather than DC servos which are of course more complicated. Very little of what you see on that board is in the signal path.
Ahha. Sounds good!
Re: Re: Diodes
SimontY said:
Definitely. I found schottky diodes to provide a sweeter, less grainy top end.
Soldered in my transistors last night for my discrete passive filter and buffer (Ray and Jaap to thank for the design!) Just need to buy the resistors and sort out some regulators and then I can test it.
Simon
Hi Simon..
Looks great. From where did you get the Wimas ? I have similar ones, here used as DC blockers in a prototype pre. Mine are +15 years even closer to 20 years old. Don't say that they are new!
opa627bp opamps question
hello, i was just wondering has anyone tried using the opa 627bp single dip package in the 67se model by turning them on edge and using 2 to replace each, dual opamp? i was told on another forum, that if using single dip packs to replace the dual dips that any, unused pins should be tied to ground? any thoughts on this grounding idea also? Thanks very much for any info! 🙂
Thanks for the confidence Simon! Can't wait to hear what you think of the sound.
rowemeister said:
Here is a piccy Simon requested of my latest upgrades.
Custom Oak rack with Russ Andrews Torlyte platforms
And ATC SCM40 speakers
Brent
Nice setup Brent! I like your rack, very nice.
But what's that Yamaha-thing doing there at the bottom? 😀
Ray
Hi Ray
The rack has provided so must more depth and control to the music, worth every penny. The speakers have great bass and very accurate natural midrange with what appears to be no colouration. I chose these as allthe reviews said they are very revealing and show up weaknesses in any system very easily, fortunately everything appears to be in order.
The Yamaha is a modded DSP-E800 processor. It supplies my three KI amps with 5.1
Brent
Re: opa627bp opamps question
Just get some brown dog adaptors - they're cheap enough (from www.cimarrontechnology.com).
This one for dips
This one for SMD
You just leave the offset adjust pins unconnected - don't ground them! You might ground unused inputs if using half of a dual op-amp but that's not what you're doing.
2xOPA627 sounds good. I found that putting an LM6171 in the first position (the one connected to the DAC) and an OPA627 in the second position was rather better though.
I used SMD and put LM6171 on the top and OPA627 on the bottom. All were free samples. 😀
hi, i found i had a brown dog for two single smds so, i had some ad8610s which i used for ic 1 and ic 2 and i also had a brown dog left which was suited for one of the ad8620s that i used to replace the other lm6172. they seem to sound very good now! smoother than the 6172s in the midrange band even with good decoupling on the 6172s and also, they have good detail. i may try something else later lol! thanks very much for your help! 🙂
AD8065x2 (or AD8066) is also well worth a try!
It's fun to try all these when those adaptors are so cheap and it's so easy to get free samples. 🙂
hi, if i were to use two brown dog adapters with ad8610/opa627au on each one, should the 627s go on ic1 on both brown dogs and the 8610s go on the bottom ic2 of both brown dog adapters or am i all confused lol!
😕 thanks again!
