RCruz said:Final overview:
6 TX (9 independent psu´s)
12 regs (3 spowers + 3 srayregs + 5 LM340AT + 1 stock 79M18)
2 x clocks (Dac and Servo)
Sound is awesome![]()
Getting there Ricardo 😉
Good work 😎
Brent
Yeah and when thats finished you could consider halving the impeadance of each supply by adding a second in parallel😀
???Glenn2 said:
Seems to back up what Illimz was saying (before you lot scared him off!).
You are joking.... right ?
But the ideae is very good... I am already searching for a second 103 PSU for my Meridian setup.
can someone guide me how to connect the low jitter clock & where to get the input supply on my marantz cd67se cd player?
Hi GlennGlenn2 said:Hi chaps,
This powerpoint file caught my eye.
Seems to answer a few questions some of us had about grounding around the DAC.
Note that supply currents for SM5872BS are:
Digital - 15mA
Clock - 3ma
Analog - 1ma
Nice to have it explained in a Sesame Street fashion with lots of diagrams.
Edit: It's from Analog Devices, who know a thing or two about DACs.
This makes sence....
sherphing said:can someone guide me how to connect the low jitter clock & where to get the input supply on my marantz cd67se cd player?
Malefoda said:Tap supply at C813 if I remember well?
Right
get power on C813 just before the main +5v reg.
I've undertaken a few more mods today as it's been a while.
I replaced the 2x BHC Aerovox 40V 10000uF caps (for clock psus) and replaced with 2X 35V 22000uF Mundorf HC.
I have also ripped out 4x Audiocon super reg that fed the HF RF and Servo 5V rails and replaced direct to pcb with 4X SPower regs. This now means I am running 21x SPowers
Also I have moved the 2.2uF Mundorf Supreme Silver/Golds on the output externally so that I can fit some more inside across them to boost the bass a little.
Here is the upgaded PDF
Pics to follow
Brent
Pics to follow
Brent
Here are a few pics
http://www.audioupgrades.co.uk/images/system/CD63KI Nov 2008 (1).JPG
http://www.audioupgrades.co.uk/images/system/CD63KI Nov 2008 (2).JPG
http://www.audioupgrades.co.uk/images/system/CD63KI Nov 2008 (4).JPG
I will leave it till after the weekend as the player takes a good 3 to 4 days to settle down (That's why I always upgrade on a Monday) before I comment.
Brent
Brent
SimontY said:
I treated my CD63 to a new interconnect I knocked up yesterday (took aaages).
Oh, it's good, beating my previous copper one and maybe even beating these solid cu connectors & Kimber 4TC we tried!
Hi Guys, long time no speak.
Been skulking around the thread for a while when I've had the chance, some great work been going on, especially Ricardo and Brent - those pics of the SPower forest look awesome, mate!
Those interconnects look nice, Simon. Is the ribbon from a PC or something? I've seen a silver interconnect somewhere on eBay that's supposed to be a flat conductor coiled round in some way, and I wondered whether you've used a flat single conductor or a ribbon like I said?
Keep it going guys.
Cheers
Jim
Cheers Jim
It sounds ok too!! Simon heard it running today at my work, will have to get him round to mine soon for a session.
Brent
Brent
Malefoda said:I see my CD53 is no match for yours now 😉
Great work Ricardo !
Thank you.
Of course, if you keep modding you surelly can surpass mine... I always admired your neat work.
Ricardo
Awesome work !!! I am really glad you keep doing these things.
How much uF can we increase in the output caps to get a better bass rendition ?
I read about bypassing these caps with a 0.47uF BG N... is it a good idea ?
PS
Love the outside caps look 😀
Ricardo
Ricardo,
You wouldn't want to bypass a Mundorf Supreme with a Black Gate! Only some combos of bypass will sound correct so don't lose sleep over this.
Simon
Simon
Hi Ricardo
Thanks 😉 I wired them with Kimber AGSS
The uF on the output will depend on a few factors. Are your leads attenuated and what your amps input is.
What ever you have at the moment tack another cap of equivalent uF across it and see if there is an improvement in bass. If not then it's not necessary. I have no issues with the 2.2uF at home but on my works system the bass is definatly rolled off. So I have fitted a second pair of 2.2uF caps across and the bass is back.
What uF do you have now?
Brent
Brent
jimh0612 said:Those interconnects look nice, Simon. Is the ribbon from a PC or something? I've seen a silver interconnect somewhere on eBay that's supposed to be a flat conductor coiled round in some way, and I wondered whether you've used a flat single conductor or a ribbon like I said?
Hi Jim, thanks. They're Mundorf copper foil, sourced from Lee. It comes bare so I insulated this with masking tape. I've since redone my pre-amp wiring with it, using acrylic pcb lacquer as the insulator. I would like to try something non-plastic though, such as the controversial C37 lacquer. If I went that far I'd source pure silver foil too I think.
rowemeister said:Cheers Jim
Brent
Even in that sub-optimal room you can tell it's a special source, good work mate. Would love to hear it soon!
Simon
Ricardo is using 4.7uF MKP. I think that a bypass with a BG would not be beneficial. Maybe a 0.47uF Mundorf Supreme or bettter would bring benefits, but I need to experiment a little more before recommending anything.
Cheers, Lee.
Cheers, Lee.
4.7uF should be well on top of the job. If Ricardo wants even more sound quality from his output then I recommend a Supreme range of cap.
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
