Yes do it. The cd player is less sensetive to poor gnds than an amp but the principle is still the same. And once you have a star gnd installed you can run all new psu gnds to it.
Brent
Brent
rowemeister said:Yes do it. The cd player is less sensetive to poor gnds than an amp but the principle is still the same. And once you have a star gnd installed you can run all new psu gnds to it.
Well that will be easy... my mains are earthed.
What type of resistor should I use... bypassed by a cap (small big?)
Can you suggest a good value (my mains are rated at 220V)
Ricardo
I mean... I can not earth the thing directly to mains earth, can I ?
I have seen some circuits where a small resistor is used (6ohm) and a small cap bypassing the resistor.
Comments please.....
Ricardo
Ricardo
I have installed a "ground lift" switch in mine so I can easily try it either connected to house earth or not.
If you permenantly connect it but get an earth loop hummm you may want to connect it via a resistor. Brent does this with something like 10R or so.
Simon
Simon
Yep I used a 27 ohm 2W resistor from star to earth on IEC socket to eliminate a small hum. The small hum was actually caused by another piece of equipment. I have a resistor on all my equipment now.
Brent
Brent
rowemeister said:Lurking lol
Good to hear from you Ray
Brent
Hi Brent,
I see business is as usual here 😀
Yep pretty much lol. I have to post in bursts between my work 😀.
Upgrading quite a few cd players at the moment, we have a Marantz CD6002 and Cambridge Audio Azur 640 V2 in. Both nice cd players with a different approach to where the design of the circuits. Marantz goes for its usuall nice caps in vital areas approach and decent rail seperation where the Cambridge as fitted a better TX and concentrated on the clock and servo areas. A combination of the two ideas would sound very good.
The Marantz has the edge overall but both sound very good for budget cd players (£250-£300 range) both miles better than a cd63 in standard form.
Brent
Brent
Oh the 6002! That's a pretty decent player. Pity it uses the Sony transport 🙁
But the DAC is not bad and NO opamps in the analog section! It looks a bit like a shrunk SA7001. Only the SMDs are a bit fiddly. Do you have a manual you would be willing to share? 🙂
Ray
Ray
I do have a manual yes, it was sent in paper form though and we dont have a scanner at the mo.
I'll see what I can do though 😉
Brent
Brent
I agree about those new players. Compared to a CD63SE (stock) the Cambridge cuts through the grime and is LOADS better. The Marantz reduces the glare of the Cambridge and is more natural (no surprise as it has no op-amps!). Superb value for money if you're buying new.
Simon
Simon
I agree, the newer players benefit a lot from the technique used in the more expensive models. A 'budget' player can outperform a stock CD63/67 now. The 6002 is a good example indeed!
I recall paying about 360 euros for my CD67OSE at the time. If you look at the 6002, it's almost at the same price level here!
Ray
Ray
Right Im going to sell my cd-63 then and get a CA !!!
Prevention of unlawful destruction when I next open. Might try source some black gate standards, and will finally install my CMC RCA plugs. No more major mods from me until I eventually get my act and accounts in order and think about letting brent loose on my player.
Im lurking rather than posting, but am planning a speaker cable build, so am hanging around the loudspeaker area of the form pestering people for help.
On another note, parents bringing the new amp down this weekend and I can't wait. Heard it at home the other week and it made my Monitor audio B2s sound very good indeed, now I can't wait to see it tame the ATCs.
The CA would be nicer to work on, but the Marantz has the nice output stage and is sonically a large step up....
Ad - your player should smoke the CD6002 stock anyway, so don't worry ;-)
Talking of smog, hope you're enjoying your new expensive environment and it's all going well, work and all.
Simon
Simon
SimontY said:The CA would be nicer to work on, but the Marantz has the nice output stage and is sonically a large step up....
Simon
O my player does, every cd player that comes into the same room as my 63 self combusts in fear of a beating from the battle scarred vet that is my 63 😀
You northerners do seem a lot more friendly, the amount of poeple who give you weird looks when you look at them on teh tube and smile is funny and worrying. Plenty of women think your trying to rape them with you eyes 😀
Oh yeah he's a Landoner now
Brent
One goes to wine bars with ones aquintances to drink ones finely brewed beverages with ones overpriced nibble that they call a main course. One also wheres ones suit with pride and must have pole up bum posture and hold ones chin up high. Now one is off to high st Ken to shop for ones mistress
Im like a child waiting for this amp as I know the ATCs will sound very very differnet, and will literally be opened up. Pity my room is over 4m sqaured and the walls don't have a lot on them. I have a massive carpet infront of the tv/av/hi-fi setup but t still sounds a bit echoy and open.
Il take the lady out then when we come back il hang a few rugs on the wall
HEHE
I'm moving in a few weeks to a 22' x 13' room fitted with a seagrass carpet (firing down the length of the room). I'm hoping the acoustics will improve drastically over my 12' x 12' room i'm in now with lamitate floor.
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
