Marantz CD63 & CD67 mods list
Have You additional transformer to analog or digital section?
It's for the analog section.
Franz,
Do you have a schematic of the passive circuit you use?
Is there any noise residue with this passive circuit?
Absolutely no noise, just music!
Gerald Gessner is selling his modifications, so I am not allowed to publish the exactly circuit.
It is really just a LC filter, 1mH in series with the signal, 10 nF to ground.
And: no output cap!
When I use this player with my DC coupled PL519 amp, then I have absolutely no cap in the signal path after the DAC chip.
Franz
Hi 6h5c,
Sorry - just a couple more questions!
I have just breadboarded my version - not connected to the cd-p yet. Nothing went BANG !!!
Did you use ecc88?
What B+ did you use?
Did you check the current through the FET?
What voltage did you get at the A-K junction.
Andy
Morning.
Just a little update on my player.
I used sound deadening material on cdp and amp and I am very impressed with the out come. The bass is deeper and the treble is more controlled, I knew it would help but not this much :D
I have also changed the 7918 for a 7912 for a dimmer display.
I have now finished my reg pcb fully, I now have an Audiocom super reg for the +5V clock reference on the DAC.
Here is a pic of reg and of pcb......dont know where the tube stage will go. lol
rowemeister said:
I have just taken off the bottom plate of the KI and bonded it with Aluminium paste (used to repair gearboxes etc). I wont come off now. lol
I did this has I felt it was not making the best contact across the whole chassis as it could so damping was suffering.
Hi.
One thing I noticed, about my '63SE, was that the bottom plate when hit really rattled!!!!!!!!! I suggested, earlier in the thread, that glueing it down was a good idea also a 12mm mdf 'plate' glued to the underside adds to the chassis damping and stiffness.
Andy
poynton said:
Or a noisy tube or FET ??
I would also be tempted to play with the values of the 620pf caps ?? The original circuit has more filtering - a passive filter may also be an answer??
poynton said:
Did you use ecc88?
Hi Andy!
Well, I know a bit more now. The remaining noise is not coming from a tube or the FET.
I measured in my CD63 to compare the results, and it too has this noise at the output :eek:.
Would you, or somebody else with a scope be so kind to verify this on his player? With the player in stop-mode and no muting circuit and HDAM installed, I can measure allmost 20mVpp.
For Thorstens circuit I used ECC82 on a B+ of about 220V. I didn't have 4k7 around for the PSU series resistor, so I gave each channel a 6k8. I upped the B+ a little so the voltage behind it reaches the desired 190V. The A-K voltage should be about 100V. The voltage over the FET is less than expected, because the DAC's 2,5V DC voltage is divided by the 10k-22k combination. The current through the FET is about 4mA. The FETs are not very equal....
Regards,
Ray.
And: no output cap!
Franz
Thanks Franz. I think the noise is there, but you'll have to set your volume to max. to hear it. The tubestage's amplification is less, so I noticed it when I turned the volume up.
rowemeister said:
I have 22mV on outputs with no HDAM
Thanks Brent, for measuring so fast :up:!
Thank goodness i'm not the only one, apparently this is normal for this player.
Regards,
Ray.
Bas Horneman said:
Hi Ray,
Just popped in to say this is indeed a cool thread...!!! Plenty of co-operation. And a lot of interested parties.....gotta get me an old Marantz somewhere..;)
Regards,
Bas
Hi Bas!
Thanks for the compliments! How's your PP project?
I haven't had time yet to put your chokes in my amp, but PSU designer shows it's a good thing. Been busy with this tubestage...
Maybe next week, I'll let you know what the results are.
I've got a CD63 for you, but it's already modded....
Regards,
Ray.
Regards,
Ray.
HI.
To find the source of the noise and so reduce / eliminate it, you need to measure earlier preferably just after the dac.
Andy
Haven't started yet...maybe tonight :smash:
NO hurries mate.
Thanks...but that would be a waste of a great sounding CD player..since I'll would probably end up using it as a transport for my RAKK DAC.
