Got it fixed. Gee so much improvements after replacing opamps, a number of caps, bypassing hdam etc
you guys rox!
you guys rox!
Chivvyp said:
Looks like the clock is slow powering up. I spoke to Audiocom today and they said it was possible but they'd not come across the problem with a CD67 before. Anyway I'm going to send the clock back so they can check it out.
Thanks for the advice.
Pete
Got a replacement clock from Audiocom (they sent a version with a reduced cap size). All working ok now.
Also fitted AD8620s (as National didn't want to send me LM4562s
😡 ), nice improvement on the AD827s that I had in before.
Pete
jksmurf said:
Sounds great, where did you put it in your PC? on your sound card?
k.
lol, I didn't put any in my pc, just in my preamp, which my sound card feeds! The sound setup in the pc is nothing special, will get something nice and external and then it should be really nice... but that's just OT 😉
WOW.
I have just done the ultimate mod. Ive upgraded the processor.
Its a very tasty mod indeed
Sorry
Brent
Sorry
Brent
rowemeister said:WOW.
If you redo this mod with a Galaxy or Mars Bar, I think you will find the result 'Out of this World' and a lot smoother without the crunchy textured edge.
Andy
😀 LOL
Andy
HAHA, maybe try a ferrero roche as they have a liquid core that will help remove the veil present in the twix and mars samples.
Would anyone be able to confirm for me whether Farnell part number 1100367 is suitable for the Acoustica clock hack?
Cheers
Greg
Good evening fellows,
once again I have a question, and now not about any rice cooker or toaster.
Ray's made many versions of his list, wich seem to be living and upgraded as the player and xp enlight us.
But has I have some problems about one or two parts, I've checked the last list : many have changed! What should I do? I've just soldered many new expensive things on it, should I change some? E.g. Q811, was MC7805ACT and is now LM340AT-5,0, or some changed values here and there ( 47n MKS in the PS instead of 22, C605/606 from 470p to 430p, R605/606 from 10k to 14k...).
Any changes that should be done?
At least I'll upgrade the parts wich remained unchanged on previous lists but now.
And second question, any way to do easier that solder the very very small 100n X7R (C136/137/146...)? Ray it seems you have blue things that seem easy to solder on the pics on your site.
A third one: Ray, why each time "ferrite x2"?
Thanks guys!
Matthieu
Thanks guys!
Matthieu
Cheers
Greg
I used these :-
http://cgi.ebay.co.uk/100nF-Ceramic...oryZ4662QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Andy
Those are very cheap but I notice the Y5V dielectric characteristic is quite poor compared to the X7R. I'm really no expert on this but Acoustica do suggest X7R, as do the mods lists.
Having thought about it, though, the tolerance to temperature is perhaps not so important (particularly for bypass caps) because my player is unlikely to be operating outside, say, 15 to 35 degrees ambient temperatures.
Andy, did you also use the Y5Vs for bypassing other caps? If they're also suitable for that then I'll go for them at that price.
Cheers
Greg
Cheers
Greg
6h5c said:
Just send me a personal mail and i'll mail you a DOC, or RTF or whatever you like. Regards, Ray
Hi Ray, got the file, works great opening it in MS Word viewer, thanks very much for that, I will make a table in Excel.
I tried to email you back but it was rejected?
This Message was undeliverable due to the following reason:
Each of the following recipients was rejected by a remote mail server. The reasons given by the server are included to help you determine why each recipient was rejected.
Recipient: <RaysEmailAddress_AT_quicknet.nl>
Reason: rejected because 218.102.23.142 is listed at psbl.surriel.com Listed in PSBL, see http://psbl.surriel.com/listing?ip=218.102.23.142
k.
Bah my cap upgrades and output area installation was going swimmingly until my sodlering iron blew 🙄
adfinni said:Bah my cap upgrades and output area installation was going swimmingly until my sodlering iron blew 🙄
Now you can add cold soldering iron to your signature
allan
Cheers
Greg
Yes, a liberal sprinkling !
Lead spacing is only 2.5mm and they are physically small which is convenient for getting them tight into the chips etc.
Andy
Edit : Oh, Look who posted this !
poynton said:
How do you blow up a Soldering Iron ???? 😕
Edit : Oh, Look who posted this !![]()
I know, i kill something new everyday. It was a cheap 18W antex soldering iron. i was changing to a new 0.5mm tip as my old one has lost a bit off the end and was about 1mm now. WAs doing the tyypical twist and pull action to remove it, which wasn't working as i realised the whole shaft was moving 🙁
I thought that was a bad sign, but got it off anyway, replaced the tip, powered on, and FLASH- BANG- SIZZLE comes from the inside of the iron.
LOL
Is it worth getting an adjsutable temperature iron, as they seem to be about £45 where i could jsut get a replacement for the one i blew for £15 which will work fine as long as im carful ?
ad
- Digital Source
- Marantz CD63 & CD67 mods list
