A desolder gun does not distract heat from the pins/pcb. Solder wick does and so is safer for the brittle paperboard philips pcb's
So I guess I need to learn how to use it 🙂
A member on a swedish forum has 122pF 1% Silver mica's.
According to clock document this should result in a lock(DEM).
Price is nice too, 50p each.
235.2 KHz, 350pF
256.58181 KHz, 318pF
282.24 KHz, 300pF
313.6 KHz, 260pF
352.8 KHz, 250pF
403.2 KHz, 203pF
470.4 KHz, 180pF
564.48 KHz, 145pF
705.6 KHz, 122pF
These will all do it - take your pick
Andrew
282.24 KHz, 300pF
313.6 KHz, 260pF
352.8 KHz, 250pF
403.2 KHz, 203pF
470.4 KHz, 180pF
564.48 KHz, 145pF
705.6 KHz, 122pF
Andrew
235.2 KHz, 350pF
282.24 KHz, 300pF
313.6 KHz, 260pF
352.8 KHz, 250pF
403.2 KHz, 203pF
470.4 KHz, 180pF
564.48 KHz, 145pF
705.6 KHz, 122pF
Andrew
Yes, I'll get these I've been offered 🙂 £1 for one to each of my cd players is very reasoble.
http://www.fidelityaudio.co.uk/1541 clocking_03.2ver.pdf
Try and copy / paste this if you have not read it already.
Can you guess who wrote this ?
Try !!
Try !!
Try !!
Posting from my iPhone, but I have the clocking doc downloaded in pdf to my pc.
Did you read it all ?
I'm absolutely sure this is UV101's paper.
Maybe you knew that already
I've read though it twice, but not yet studied it.
I was going to say UV101, but got insecure 🙂
From what I've gathered, there are better dem locking methods, but non as simple as putting a cap between two pins 🙂
There is a significantly better way and..... it's on UV's sheet
The cap across 16 - 17 is a just a taster !
Ordered two 122pF caps from him now (he measured the 20pcs of 1% caps he had and sends me the two that differs the least from 122pF). So I get less then -+ 1% on the caps I recieve 🙂
You have a supplier of components thats open for orders from an IPhone on Sunday at nearly 11 pm ?
....and he even discusses looking for the best tolerances ?
Give me his website details - I have an order to place !!
I was just kidding - you know that 😉
Very lucky to have your supplier on your Blog too !
I know 🙂
You're talking about UV101, who's offered to get me the caps I'm having trouble finding?
- Digital Source
- Marantz CD-50 and CD-60, TDA1541, CDM4/19
