I have bought a Maplin 100WRMS mosfet amplifier off ebay that hadn't been built, it was still in kit form. As rare as rocking horse droppings !
So I built it up tonight and it worked first time after all these years.
Sounds very good.
Sounds very good.
Positive karma - I hope.
This is exactly the board and components (even to the the "staining" on the o/p Hitachi TRs) that you very kindly helped me be confident enough to power up last November.
Mine continues to do excellent duty driving a pair of same vintage Castle Conways thus making my Television sound much better than it did.
The flange of the To3 looks quite thick.
Can you tell if the flange is aluminium or steel?
Does the contact face of the flange have an insert?
Probably only steel could be as thin as the cover and still be welded consistently to the baseplate. It certainly is steel, even being a little rusty, hard and magnetic so you can lift them even with a weak fridge-magnet....😉 I have a 2SK135 and a similar few vintage Hitachi TO3 transistors that have just as thick a base (3mm) that is light and soft enough to be scraped like aluminium. I'd guess they are an aluminium alloy suited to the type of weld used.
Perhaps the "insert" on the base is just an indentation mark of the bottom die of the welder. That can be any size or none at all depending on the die and whether it's for attaching a heat spreader, or the cover.
Trip down memory lane.
I built more than 20 of these kits for me and friends when I was a teenager. Each one worked flawlessly. 6 modules were employed as Pro amps and used to power the speakers in the school hall where school dance parties were held. Never did one fail, that is upto the time I left highschool. Thinking of which, they probably still there.
I had to fix a amp for a church about 10yrs ago.
Turns out it was a DIY amp, based on the Maplin MOSFET amp.
The two modules were attached to the same heatsinks, with the one module mounted upside down.
One channel still worked, turns out it was the upside down module that was faulty.
I measured the output fet to be a short.
When I took out the fet, I saw that one pin was soldered to the case.
I cleaned of the solder and put it back in, working still today.
Turns out that the module got so hot that the solder on the pin ran down the leg, shorting it to the case, very hardy amps.
This was also the first discrete power amp kit I built while at school.
These Hitachi MOSFETs were the best I got into my fingers ever. In the eighties I built several 5kW Monsters each with 36pairs of 2SK135/2SJ50
The top metal has oxidised just slightly since the 1980's so I would guess it is aluminium. The base looks aluminium too.
The transistors are just standard TO3.
The heatsink had quite big holes drilled in it for the isolation bushes.
You need to uprate the series resistors to the Mosfets or
it will inevitably die at some point, I recall 100R to 270R.
Fine at low volume, but it dies being being hammered.
rgds, sreten.
YMMV, but I've had bad experiences driving said amplifier
hard. The flange in the kit I had I recall being aluminium.
The devices being steel T03's.
rgds, sreten.
I am currently working on a update to the Maplin mosfet amplifier circuit.
I have added a Vbe multiplier, added 390R gate resistors and changed the mosfets to irfp240/9240 with source resistors.
A Vbe multiplier is chasing your tail as there is no optimum
bias point that needs to be maintained for a Mosfet pair.
The bias point is so arbitrary it has no sensible purpose.
Similarly source resistors serve no useful purpose for bias.
Mosfets are not BJTs and cannot be treated the same.
In the Maplin circuit the output will only swing to 7V or
more (depending on the load) below each rail at best.
The high voltage drive needed for each device renders
any sort of BJT bias schema completely irrelevant.
rgds, sreten.
rgds, sreten.
I need to set the current through the Vbe multiplier to around 7ma to keep the transistors working within their spec.
I am using 600mW transistors in the VAS and LTP stages.
I have designed a few hexfet amplifiers and they do need a bias voltage to stop crossover distortion. Having said that I found I could get away with just 10mA to stop crossover distortion.
The point of a Vbe multiplier is thermally linking it it to
a BJT output stage for thermal tracking. Mosfet bias
has no use for such tracking and many bias options
are available, including a simple resistor in tandem
with the bias current of the output driving stage.
rgds, sreten.
rgds, sreten.
I am using hexfets which can suffer from thermal runaway.
That's why I have mounted the Vbe multiplier transistor on the heatsink.
Lateral mosFETs in the output stage do not need extra temperature compensation for the bias current.
Vertical mosFETs and BJTs NEED extra temperature compensation for the bias current.
There is some point where biasing resolves into utter
nonsense trying to control the consequences of poor
heatsinking, good luck with that, I'm not interested.
Decent heatsinking and simple is my opinion.
BJTs need optimum bias for distortion, not thermal
issues, and Mosfet bias doesn't, only thermal stuff.
rgds, sreten.
rgds, sreten.
rgds, sreten.
rgds, sreten.
I have used a vbe multiplier to generate a stable bias voltage in my latfet designs. The bias generator was mounted well away from the fet heatsink. JLH did the same for his 1982 design in Wireless World.
Steve.
Steve.
I am currently running the Maplin mosfet amp at zero bias and it sounds fine.
My previous hexfet designs suffered badly from crossover distortion if I did that.
Just put together a lateral mosfet based amplifier.
Its based on the Maplin/Hitachi designed.
I am using ALF16n16w/ALF16p16w mosfets.
I am waiting for pcb's to come so I can build one up.
Ahh, remember the Maplin MOSFET modules too, used them in my first DIY build as a spotty 20-something engineer🙂 Rather ambitious project because I built a seperate PSU along lines of Cyrus PSX and used identical case for the amp. Front-panel mounted heatsinks that looked (and ran) cool even if there was nothing else apart from amp modules. Don't think the THD figure was particularly great but boy did they sound good😀 Will definitely be interested in your progress and results.Maplin MOSFET amp revival long overdue😉
- Maplin 100W mosFET amplifier built from 1980 kit
