LuDEF
The mouse that roared?
Can the LU1014D become the mouse that roared?
Yesterday I received 50 each LU1014D from the EBay source recommended by woofertester. They look like the real thing: factory style packaging and no indications of any previous use.
I did a line-up of 6 different transistor packages. Amazing difference in package size and heatsink contact area.
I plan to experiment with several heasink options and stress test the LU1014D up to about 10-20 watts.
LU1014 junction to case is 0.5W/°C.
20 watt gives you dT of 40°C.
Assume heatsink temperature of 55°C (due to the cascode MOSFET), junction temperature will be 95°C.
In comparison, 32W for IRFP240 gives 82°C junction for 55°C sink.
I hope you have real good speaker protection circuit. 😉
Patrick
I need to build a cascode test circuit to determine the 2nd harmonic "sweet-spot" behavior. There are 3 parameters to consider:
  1. bias current Id
  2. LU1014D Vds
  3. resistance between LU1014D drain and cascode FET source
The LU1014D power dissipation will be Id*Vds
Hello
Can you share your ebay source?
I will crank up my FrankenTracer and see what I have. It might require some modifications for the limited Vds voltage range of the LU1014D. I will probably just use a lower voltage transformer.
Woffertester:
How did you do Frankentracer curves without exceeding Vds limits of the LU1014D?
I have access Keithley sourcemeters and associated software. Limits for current and voltage are explicitly set. Power limits can also be set.
