Low power tube amp for headphones
This was the first power supply I thought about using...
It seems as though a Hammond 269AX transformer would work. I think... It puts out +125-0--125, and then when it goes to the rectifier, I get 250VDC, right? It is only $37 at Digi-Key, too, so it can probably be found for less...
On this same power supply, since it puts out 230V, couldn't I just add a resistor, or raise a resistor value to get the 220V I need?
I am having troubles with resistors again... It is stated that all resistors that are not marked should be 1/2W. Is this necessary? I cannot find any 1M ohm resistors that are 1/2W and 1% tolerance. I am guessing 1% is far better than the standard 5%... so that is why I ask. Is 1/4W sufficient all the way around except those marked with special watt ratings?
trespasser_guy,
IMO 5% is accurate enough for this.
To the best of my knowledge, resistors above 1M are not available in close tolerance.
Regarding wattage: Because higher power resistors are physically bigger, they generally have higher voltage ratings. For that reason, I'd chose 1W over 1/2W for any resistors with volts across them.
CURIOUS.
Don't worry,it's a healthy attitude.😉
what made the second circuit better than the first?
First of all,why use // tubes when you don't need them?
The second circuit will drive the most ridiculously low impedance,hence it would be better suited for the low impedance type of cans.
I know the capabilities of the White CF when it comes to that,so I feel comfortable recommending it.
That's actually my favourite of the lot although I would use the 6C19PI nowadays to make it more compact and in line with the noval input tube,which I would replace with a 6N1P BTW to keep cost down.
At the end of the day the choice is yours of course,😉
I am just not sure which way to go... each has their pluses and minuses to me- something I don't understand about.
On the one by Waarde, it says to note that C1, R5, and C2 are shared by both channels. How does this work? Just basically add C1-R5-C2 to the power supply and then run a wire to each channel?
I am not too fond of havig to use an IC in the heater supply either... or a pot for that matter. Could I use the hater supply from another amp for this one?
IN DUBIO.
I'd welcome someone elses' opinion on this too,I can only recommend what I feel is the most versatile of the lot.
I'm not too sure what is meant by his comment here but I would certainly advise against sharing these components for both channels.
Just use all components for B+ in the same way for right and left channel starting after the choke.
You could,OTOH I don't see anything scary about it though and using regulated DC here would help S/N.
There are different ways to go about it,the major problem being the hefty heater current needed by the 6AS7G: 2.5 A.
Cheers,😉
