Low cost ES9018 DAC board GB
There is no link available, you can ask your country ess distributor regarding this. There are few new functions the gpio pins can be configured to have spdif input, now we can have up to 5 spdif inputs, over sampling filter bypass, custom programmable FIR filter coefficients, minimum phase filter, also one regulator can be omitted from the existing schematic.
Sent from my Q700i using Tapatalk
Ok, what the heck. I'm in...
1) syklab - 2 PCB, 2 ES9018K2M (pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
4) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
5) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
6) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
7) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
8) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
9) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
10) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
11) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
12) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
13) DaveK - 1 or 2 kits
14)OverkillAudio 4pcb, 4 ES9018
15)Cristi289 1kit
16)Turbon - 1 PCB, 1 ES9018K2M (pre-soldered)
So
15)Cristi289 1kit
17)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
New update... there will be additional I2S isolation feature on the DAC board. On the test board I did not put that but on the new board members will be receiving it will be there. Buyers can populate or not populate the I2S isolator section at their own discretion.
