When I signed up for this I imagined it would have been all thought through and it was just a matter of joining the dots.How am I going to know where to solder the components? As in different values of resistors and capacitors etc...Is there a schematic to work from?
I understand a full schematic will be provided after Gb not the blank schematic shown.
If its available why cant I see it now? I'm sick of continually trying to get info on this,there's something wrong here, so I'm out.
1) syklab - 1 PCB, 1 ES9018K2M (pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
4) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
5) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
6\7) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
8\9) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
10) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
11) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
12) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
13) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
14) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
I'm out too.
I'm out too.
https://drive.google.com/file/d/0B2ArnRLTrdN0cF80V3RMQWlxVHc/edit?usp=sharing
https://drive.google.com/file/d/0B2ArnRLTrdN0OFFpaVBJWVk3Z0E/edit?usp=sharing
I have included a replacement for the crystal in the bom which is available at mouser
Sent from my Q700i using Tapatalk
Layout
https://drive.google.com/file/d/0B2ArnRLTrdN0V0xRT0o5SGV3Slk/edit?usp=sharing
https://drive.google.com/file/d/0B2ArnRLTrdN0UWdMQkJRU3Qta3c/edit?usp=sharing
Is the group buy still going?
Yes , and I have all the info I need to make this DAC .
Please mark mine unsolder , as I can solder myself.
Small update: Everyone participating in the gb will get the code to run the DAC. Initially the DAC will run on the default register settings requiring no user intervention and will run like a ES9023 but with automatic signal detection and default filter settings and there will not be any need for LCD display and encoder. All participants will get a software update little later and they can add an LCD display and encoder to their existing setup if they want and will have full control over various settings of the ES9018K2M......thanks
4 mono boards & unsoldered ESS DAC chips
Hi Syllable,
Subject to the full schematic, BOM and instructions being supplied I will go for
4 mono boards & 4 unsoldered ESS DAC chips.
It would be ideal ( more UK buyers) if you could also supply any key parts which are on longer lead times in the UK.
Derek.
Hi Syllable,
Derek.
6) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
7) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
8) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
9) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
10) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
11) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
12) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
13) DaveK - 1 or 2 kits ???
14)OverkillAudio 4pcb, 4 ES9018 ????monoboards not available
15)Cristi289 1kit
So Syllable, let's make things more clear for everyone, you will provide for 20USD per pcb and 20USD/dac chip:
-full schematic (already done in my opinion)
-BOM (already done in my opinion)
-software and instructions how to program the chip
I think people would be more interested if information about this GB is more consistent and well presented.
15)Cristi289 1kit
Mono boards you can give a skip at this time. I have put a temporary hold on the mono boards. It is little costly to make than a ES9018K2M. So when more people are interested I will think about it. So for time being I am just offering this ES9018K2M low cost DAC only, you can give a skip to the dualmono... Thanks
1) syklab - 2 PCB, 2 ES9018K2M (pre-soldered)
15)Cristi289 1kit
15)Cristi289 1kit
8) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
15)Cristi289 1kit
15)Cristi289 1kit
- Group Buys
- Low cost ES9018 DAC board GB
