Ok, ...
1) syklab - 2 PCB, 2 ES9018K2M (pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
9) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
10) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
11) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
12) DaveK - 1 or 2 kits
13)OverkillAudio 4pcb, 4 ES9018
14)Cristi289 1kit
15)Turbon - 1 PCB, 1 ES9018K2M (pre-soldered)
16)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
14)Cristi289 1kit
Here is the board everyone will be receiving. It slightly differs from the test board. I have made provision for isolated i2s feature, only one ic, two caps and one smd switch are needed to be added to the existing bom. Buyers can populate or not populate the isolated i2s section. Even if it is populated it can be enabled or disabled with a small switch. The spdif signals from two onboard receivers can now be connected to the GPIO pins so that the spdif and i2s can be connected all the time and switched through the software, the updated board has provision for that. This will be done little later. Also the board now has provision for SOIC opamps. The total cost for the test board came out to be $90 as i already had some parts.
Provision to solder SOIC opamps at the back of the board is a clever idea
. Should pin 1 be indicated?
What isolator chip can be installed on IC1? Can we use Silicon Labs 8661 (DIYINHK Isolated XMOS USB Interface | H i F i D U I N O) there?
Here is somewhat okay photo of the ES9018K2M dac test board
Hi, why is there so much unused board space ?
BTW I2S lines all need GND between them. Also the U.FL are recommended even if their longevity is doubtful (I really don't like plugs that break/wear out so easy as those). Molex connectors are not suitable for I2S (except when one uses a GND pin in between data line pins, that would make it acceptable but not exceptional 😉 ). Data lines need to be kept as short as possible so moving them to the edge of the board would be advisable. In normal circumstances 10 cm wire is already very/too long for I2S ! The PS Audio LVDS system is a very nice I2S solution, also adopted by RAKK. In fact it would be best if manufacturers would choose this system as a standard as it surpasses SPDIF/USB big time. It is nice that cheap standard HDMI cables are used. See the following link for more information:
http://www.raleighaudio.com/I2S Interface v3.1.pdf
All in all a nice ES9018K2M board, I am curious how it will compare to the ES9018 and ES9023 boards. To my surprise some ES9018 boards are simply less good performers than ES9023 boards even though the chip is better on paper, clocks are higher and an output stage is used.
Some modifications:
13)OverkillAudio - 4pcb, 4 ES9018
14)cristi289 - 2PCB, 2ES9018K2M+oscillator (pre-soldered)
Total: 23 or 24 (Davek)
ES9018k2m is a mobile version of ES9018 but has similar features like a ES9018 except it is not a octa dac like ES9018 and hence dynamic range is limited to 127 dB. It cannot be compared to a chip like ES9023 which is inferior to features and functions. May be you can ask ESS tech how ES9018 compares to ES9023. ES9023 are for beginners.
Hi Syllable,
Could you please take in consideration to put some ufls pads on the back of the board fro I2S inputs?
For example like this ones:
U.FL-R-SMT-1(10) Hirose Connector | Mouser
KR
KR
Jean Paul the perspective is conning .
The board have max 10cm x 15 cm at all
guessing by what is in photo (approximation.)!
It is ok also with I2S how long insert on top of this board another board at 1..2 cm above with pins/wire bridge soldered between 2 boards that provide I2s from another source.
But I am in doubt that someone will use on this board something else but Spdif input !
Maybe I will put a Tenor USB module on top of this board to have also USB input .
J
I could be a cheap component in a streamer like the following:
Beagle bone black => cape for BB from Twisted Pear ( Link ) => I2S => DAC
This is why I have asked for u.FL connectors for I2S 🙂
Good luck with the sales of features and functions. You could work a bit on the PR front.
Guys this DAC sounds absolutely incredible, fast signal lock, one good news is that it does work without an MCU but if we want to access all functions of the DAC we will still need a MCU. Those who would like to go with the default values of the DAC they can omit the mcu PSU and i2c isolation section.
Sent from my Q700i using Tapatalk
Also those who do not wish to use the DAC without MCU they can omit two spdif receivers and its associated components.
es9018
Thinks are going ahead... very nice 🙂
What are default settings for that sabre dac?
Can we see some measurements for finished dac?
How can we switch between spdif inpusts and i2s input.
Is it possible to switch between spdif 1,2 inputs and i2s?
Thank you,
Thank you,
- Group Buys
- Low cost ES9018 DAC board GB
