Low cost ES9018 DAC board GB
Good news! I have been informed new stock of the IC has arrived, so I will take the orders. PM PayPal id with number of boards required with IC soldered if needed. I will quote the price and shipping once again
DAC Board x 1 - $20
ES9018K2M IC x 1 - $20
SHIPPING CHARGE FOR 1 BOARD - $10
SHIPPING CHARGE FOR 2 BOARDS - $15
Sent from my Q700i using Tapatalk
DAC Board x 1 - $20
Syllable,
You said you can provide crystal as well? Any other parts you may be able to arrange? Thank you. Regards.
I'm also interested in buying 100mhz crystal and some other parts like I2s isolator or AD regulators. Noticed mouser has sone Susumu thin film resistors much cheaper than Panasonic. Is Susumu a good choise as they are same technology?
All parts are easily available on digikey. In case of difficulty in finding the crystal in Europe I said i can get the crystal if it is a bulk order, I cannot do that for one or two members and all parts in the BOM. You can use thin film resistors of any make but the value should be the same. For each additional boards there will be a shipping charge $5 added, for three boards shipping charge will be $10+$5+$5 - $20. There won't be any PayPal charges 🙂
is this able to work in hardware mode with autodetection of one SPDIF or I2S signal even without arduino microcontroller?
in case one is purchasing the microcontroller can you also provide the firmware for it to be able to control this particular device?
It works only with the mcu. I will provide that to all who are going to participate in this GB as I told earlier. The crystal oscillator if members are interested i can provide at $5 each provided at least 25 are interested. Presently only few members have given the orders, so the GB is going nowhere. If members are interested I can also offer something like this to be build cheaply, a ES9018S dualmono dac, except for the dac ic everything is cheap and some parts like the opamp can be purchased from ebay to reduce cost drastically. There are two boards involved for this project and each one will cost around $12.5 again shipping cost everything are the same. The one shown is slightly a old version but new version will have three spdif inputs and one I2S/DSD input. The board uses TPS7A47 regs. If interested i can get the dac IC soldered for $60 each. Again i will provide all informations to build it cheaply as far as i could. I wont be able to provide the fully assembled one for a price as some are privately messaging and asking. We can have a separate GB for this if everyone are interested.
thanks for your answer, I thought initially that this will be able to work even in hardware mode accepting I2S and not only in software mode driven by the MCU
I think I'm starting not to like this dac anymore, it's getting too complicated for me 🙂 besides the MCU , the LCD is a must then and also a case/enclosure would be advisable so that the LCD doesn't hang around the board with all those wires...which starts to raise up considerably the final cost of the project
1 PCB and 1 pre-soldered chip for me.
I actually would like syllable to ship it together with a pre-programmeed MCU, if possible.
syllable may consider put a picture attachment in first post to gather more interest.
1) syklab - 1 PCB, 1 ES9018K2M (pre-soldered)
2) bbe - 2 PCB, 2 ES9018K2M (pre-soldered)
3) pchw - 2 PCB, 2 ES9018K2M (pre-soldered)
4) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
5) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
6) yoaudio - 1 PCB, 1 ES9018K2M (pre-soldered)
7) hsi68 - 1 PCB, 1 ES9018K2M (pre-soldered)
8) syyma - 1 PCB, 1 ES9018K2M (pre-soldered)
9) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
10) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
11) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
12) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
13) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
14) MarcellD - 1 PCB, 1 ES9018K2M (pre-soldered)
15) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
16) Stale25 - 1 PCB, 1 ES9018K2M (pre-soldered)
17) DrizztDo - 1 PCB, 1 ES9018K2M (pre-soldered)
18) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
19) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
20) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
3) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
4) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
5) yoaudio - 1 PCB, 1 ES9018K2M (pre-soldered)
6) hsi68 - 1 PCB, 1 ES9018K2M (pre-soldered)
7) syyma - 1 PCB, 1 ES9018K2M (pre-soldered)
8) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
9) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
10) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
12\1) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
12) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
13) MarcellD - 1 PCB, 1 ES9018K2M (pre-soldered)
14) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
15) Stale25 - 1 PCB, 1 ES9018K2M (pre-soldered)
16) DrizztDo - 1 PCB, 1 ES9018K2M (pre-soldered)
17) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
18) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
19) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
Removed myself for the same reason as luxury ...
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
4) yoaudio - 1 PCB, 1 ES9018K2M (pre-soldered)
5) hsi68 - 1 PCB, 1 ES9018K2M (pre-soldered)
6) syyma - 1 PCB, 1 ES9018K2M (pre-soldered)
7) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
8) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
9) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
10\1) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
11) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
12) MarcellD - 1 PCB, 1 ES9018K2M (pre-soldered)
13) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
14) Stale25 - 1 PCB, 1 ES9018K2M (pre-soldered)
15) DrizztDo - 1 PCB, 1 ES9018K2M (pre-soldered)
16) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
17) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
18) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
Removed myself
/Bo
14) DrizztDo - 1 PCB, 1 ES9018K2M (pre-soldered)
15) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
16) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
17) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
Removed myself too
When I signed up for this I imagined it would have been all thought through and it was just a matter of joining the dots.How am I going to know where to solder the components? As in different values of resistors and capacitors etc...Is there a schematic to work from?
goto leave too, won't have the time
14) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
15) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
16) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
6) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
7) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
8) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
9\1) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
10) danzup - 1 PCB, 1 ES9018K2M (pre-soldered)
11) MarcellD - 1 PCB, 1 ES9018K2M (pre-soldered)
12) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
13) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
14) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
15) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
Removed myself.
4) hsi68 - 1 PCB, 1 ES9018K2M (pre-soldered)
5) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
6) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
7\8) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
9\10) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
Wait for me!!
Removed myself.
4) redrooster - 1 PCB, 1 ES9018K2M (pre-soldered)
5) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
6\7) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
8\9) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
Removed myself too.
