Lottery DIY Sony VFET pt 2 (N-Channel) - assembly by Mighty ZM
Some dumb progress pics. I chose to bore out & tap the M3 heat sink holes to M4 as Papa's T-brackets accepted M4 bolts without need for drill pressing or other violations of His Fine Work. As implied above, my tapping job resulted in somewhat loose M4 threads for reasons mysterious so I'm trying the threadlocker approach on the M4 studs I received today. We'll see if these cure up proper. The T-brackets are just there to hold the studs in correct alignment while the thread locker cures (24h or whenever I have time to get back to this).
