please please i need the schematic diagram of europower pmp3000
this is my mail talel66@hotmail.com
thank you
thank you
Guyohm, pmh300 shd be using a sps600, get it here: BEHRINGER PMH5000 SCHEMATICS SMPS - Electrónica - Esquemas - TV - Áudio - Digital
I repaired a few of these and so far every one had power supply damage along with the amp so Amp only did not solve the problem, Power resistors r11 and r12 take a beating anlong with Transistors T4 and T3, All of mine the resisters opened and the transistors shorted, Amps were just replacing the output drivers.
Since the built in amp is pretty much a joke to start with I really would not use it unless maybe for one monitor speaker on karaoke to be honest, Run external amps.
I modded a few pmp3000's that are working fine. Pulled the power supply and amp completely out, Added a switching power supply instead, The ribbon from the mixer unit is
1 +15 volts DC ( Red)
2 -15 volts DC (black)
3 Analog Ground (black)
4 +48 ( Needed for phantom only) I did not use it.(black)
5 +5 volts DC
6 Digital Ground
Tied the digital and analog grounds together and to power supply ground, No hum.
Supply I used was +/-12 +5, Mixer works fine with that.
Just thought I would pass it along in case someone just wanted to get one running for use with external amps.
5 +5 volts DC
6 Digital Ground
Behringer sps600 power supply
any one got a schematic for this power supply. its from a behringer europower 3000 mixer
Re PMH3000
Where can i download from
Hi All I have service manual this model
you can download now!!.
enjoy....😀
Do you have schematic for Switch mode powersupply sps600. for pmh3000 or pmx3000. my email is dcmcomputersltd@hotmail.com
Hi all, I would appreciate to receive the schematics too. I've one of PMH3000 with power supply broken and no hints to start. Thank you in advance. Pls, send a copy to dcarboni@gmail.com at your convenience
Hello. I need a pmx880 behringer diagramm circuit. Pleaseeee. arteymetal@hotmail.com
Thank you very much. 🙂
Hi edsel,
Did you ever get the power supply for your MX9000 working?
I am a tech and have the same mixer and supply but no schematic.
If there is anything I can do to help, let me know.
Voltage checks or component identification and such.
Jim
Jim
Schematics for europower pmp 3000
can anyone send me the schematic diagram of europower pmp3000.
Please send it to Roadboots55@yahoo.com
thanks!
thanks!
send me please
behringer sps 400 power supply schematic
my e-mail:
gutturaldarkness@hotmail.com
thanks
my e-mail:
thanks
- Class D
- looking for pmh3000 behringer power mixer schematics
