Behringer Mixer schematic
Hello
Can I get this PMH3000 Behringer schematic.
cool_tek@sbcglobal.net
Also I have 1 channel of the Behringer EP2500 schematic if anyone can use it.
Roy
Too dang hot to solder!
Hello
Roy
Please send me any and all Behringer Schematics!! I have 4 powered mixers here to fix. 2 with class-D and 2 with AB amps.
tetech2@doitnow.com
Thank You!
tetech2@doitnow.com
Thank You!
EUROPOWER PMH3000
I need a schematic for the EUROPOWER PMH3000 please!!! The two amp boards (ones with the heat sinks on them) have torched some resistors and a couple diodes and I need to know the replacement numbers so I can try to patch this guy back together. Or if theres somewhere I can just order new boards fairly inexpensive I would be willing to take that route too. Any info would be greatly appreciated.
Thank you,
C.B.
Thank you,
C.B.
Pmh5000
Hi all,
please does enyone have the behringer PMH5000 schematics ? I found some input stage schematics on the net, but I need the stage after fader, because only left channel works.Thanx a lot. My mail is uncle.fido@centrum.cz
Hi all,
PLEASE SEND ME SCHEMATIC FOR PMH 3000 thanks
Hi,please send me schematic for PMH3000,thanks!
emilm@mail.bg
emilm@mail.bg
pmh3000 behringer powersupply
Hello!
is there anyone that knows the information
for EE-16 transformator on the powerunit
i have a faulty one and cant replace it, is
there anyone that have the behringer PMH3000 schematics
for the powerunit, or PMH1000/PMH2000
I have replaced this:
1 switchtransistor 17N80C3
power-on dip-8 TOP221P
condensator 450v 4,7uf
diod PJ45 GF1G, GENERAL RECTIFIER 400v
4 SMD R047, 0.047ohm
2 resistors 27ohm
and i have no replacement for this:
FlashBack TR-EE16/033MH00/01
Please send me schematic for PMH3000,thanks
info@datorskrot.se
i can fix hires images for the powerunit, and i'am going
to draw schematics by hand for this board lather
when it is working.
Hello!
2 resistors 27ohm
info@datorskrot.se
when it is working.
Hello!I need a schematic for the EUROPOWER PMH3000 please!!! The two amp boards (ones with the heat sinks on them) have torched some resistors and a couple diodes and I need to know the replacement numbers so I can try to patch this guy back together. Or if theres somewhere I can just order new boards fairly inexpensive I would be willing to take that route too. Any info would be greatly appreciated.
Thank you,
C.B.
I can get hires photos for you
on the AMP
BR/Jan
PMH5000 shematic
I highly appreciate if someone send me a copy to granwilly@yahoo.com. Know me at GRANWILLY_PR
Thanks,
Willy
Thanks,
Willy
- Class D
- looking for pmh3000 behringer power mixer schematics
