I have to change the laser on my 3910,while the hood is off I might at well install the XO3 that I have laying around.And change some regulators to the LM317/337 type.But firts some questions,the supply to the XO3,I could take it from the +12v line,but the sonic result will be better with a separate trafo and rectifier,or?
I se that the opams in the analog output runs on + - 9v,those regulators can be upgraded.
Then I assume the digital part runns on +5V,but there are 2 different 5v supplys(Green on the schema,+ - 9v, red)which one of the 5v regulators to uppgrade,or both?
XO3 clock in on XTI,remove C112,C118 and R127,right?
Hi Ryssen,
I think you should look at the HF performance of the regulators. Bypassing the electrolytic caps might make a far better improvement than the basic regulator. This means leaving the regulators stock and bypassing may be better all around. Just don't get silly with the caps. Small box polyesters will be just fine.
I haven't looked at the regulator specs, but IC regulators generally have trouble at the higher frequencies.
-Chris
-Chris
Yes,the ripple current is messaured at 120hz..And the only one of 7805,780-05 and LT317 that has a diagram of the ripple at different frekvensys is LT317,and it shows that the ripple rejection is down about 20dB at 20Khz compared to 120hz..Then I wonder how bad the 7805 that is the one in the player.
I have some PCB´s for a discrete regulator,maybe use them?
And I`am going to e-mail texas instruments for some more data on the
LM780-05.
Yes,I am going to bypass the electrolytic caps,thats my favorit.
LM780-05.
Hi Ryssen,
I don't know what the high frequency behavior is on these. Adding a choke and cap after these might be a good idea, and before. That reduces the importance of regulator performance at higher frequencies.
-Chris
Possibly. There is a chance the performance might be worse than what is in there. Depends. As long as you don't cause damage to the PCB, go ahead and try them. Should be interesting to see what your results are. If you can, try to look at the supplies before and after.I have some PCB´s for a discrete regulator,maybe use them?
-Chris
put snubber on the power supply diode, or better change to fast "soft"recovery type. impotant to notice the "soft" when you decided to buy one.
Hartono
Hartono
At least there is a C-L-C filter before all regulators.What value on the choke should i use after?The one before is 4,7uH.Adding a choke and cap after these might be a good idea, and before.
I´will do that.Thanks.put snubber on the power supply diode, or better change to fast "soft"recovery type
The e-lyts looks to be the cheapest type(non ESR)If I change them for
ESR types will it affect the PSU negaive in any way?(Switching PSU)
And just to be sure,if anyone is familiar with the schema,is it, "+5v_NSW" that is for the digital part?
The one marked +5v is probably for the rest,motors and stuff,I think.
The LM2940
seems pretty good on ripplerejektion,havent gotten any answer from texas yet.
"The e-lyts looks to be the cheapest type(non ESR)"
I guess you mean High ESR
"If I change them for
ESR types will it affect the PSU negaive in any way?(Switching PSU)"
and you would change the with low ESR types.
sometimes this can cause oscillation (bad) in switching PSU
Edit : if you want to change it, change the one after the choke, larger value is ok
Hartono
Hartono
Hi Ryssen, Hartono,
Often, I have found the regular diodes to be the best. Don't always rush to replace them.
-Chris
-Chris
"Often, I have found the regular diodes to be the best. Don't always rush to replace them."
I'll take note of that, I use Schottky before, it sounds better.
Edit: my cd player use linear power supply, not switching
Hartono
Hartono
even in switching regulator ?
Zener ?
no, it's completely different thing, it's mainly used for voltage reference and other things.
Hi Guys,
It depends on the application and power supply design. Notice the progression since the diode thing started. Fast recovery now slow recovery. Standard rectifiers were designed by some very bright people. They are pretty good in a properly designed power supply.
Switching supplies require fast diodes. That's why we have the faster types of rectifier diodes.
-Chris
-Chris
Only when someone is making a mistake if they are used for a rectifier. They cost more too, so I guess they must be better!What about Avalanche diods?I heard some use them.
-Chris
"It depends on the application and power supply design. Notice the progression since the diode thing started. Fast recovery now slow recovery. Standard rectifiers were designed by some very bright people. They are pretty good in a properly designed power supply."
make sense.
but wouldn't it better to use fast "soft" recovery than fast diode "fast" recovery in switching supply ?
Hartono
make sense.
Hartono
"so I guess they must be better! "
english is hard enough for some people, don't add the confusion pleazeeeee....😉
- Digital Source
- Light mod Denon 3910..
