level shifters and mosfet drivers
Tekko!
This is not clipping. This is the distortion caused by enormous dead time. You can test this: if you increase input voltage much, output voltage will be increased too, like in the attached picture.
Solution: change to IR2110, or other fast gate-driver! (But then you must do something against cross-conduction!)
This is just a prototype so i could get some IR2010 again, as well as some LT1016 comparators like titanchen used, build a new one and test again.
Tho i don´t have any 0.1µF bypass caps anywhere except over the 5v rails, so maybe the bootstrap cap (47µF) cannot do its job properly on higher freqs.
Pafi said:
Tekko!
This is also how his triangle wave looked before even having added level shifters or drivers.
Why the amp starts distorting and only gives out 10vpp cannot in any way be caused by the deadtime, its not even visible on the op waveform, and it doesent matter what the input freq is.
The modulator is also faaaaaaaar from overmodulation, on max volume the source can do the pwm is only vibrating to maybe 40/60 duty cycle, so it must be something else.
Also the input to the gate driver is not even close to a squarewave, looks more like a capacitor charge/discharge curve, tho the gate outputs are good squares.
??? What is this forum??? Too bad that you need dosens of schematics of existing circuits, much help, and some weeks to build a simple class D amp. Grow up! I hadn't seen any classD circuit before I designed (design! not randomly connect or copy and paste!) my first one, and I didn't use simulator. Use your brain finally (if you have it) instead of asking and blaming others! And don't lie that your circuit is working well, before you measure anything, because we are not stupid!
Godspeed!
Tekko don't be silly and follow Pafi's advice. There is something wrong with your modulator, the input waveform to the gate driver should be almost perfect square waves too. Also, there is no vodoo here, the steady state output voltage is always the rail voltage multiplied by the duty cycle.
Tekko said:
This time im convinced that it´ll work without a hitch, IR2111 have more deadtime allowing the fets to never cross conduct, actually too mutch deadtime but as it will be a subwoofer amp only, that wont really matter.
I´ll continue as long as i have money. I think i have enuf money to even buy one of fredos´s biggest amps.
I won´t quit.
So then what I trust you've learnt so far:
1. Don't be too quick to convince yourself
2. You at least saved a good bundle so far by doing this on a protoboard of sorts, no 100$+ PCB's this time
3. Still have lots to learn, can't expect people to keep giving you answers to easy questions that you can figure out yourself.
4. Too much time on IRC doesn't pay off
5. That'd I'd throw this in your face when you needed it most 🙂
Eva!
There is a very simple explanation.
"Also the input to the gate driver is not even close to a squarewave, looks more like a capacitor charge/discharge curve"
It can be what it looks like. Level shifter charges slowly the input capacitance of scope cable. Tau= ~100pF*6,8k=0,7 us. He probably doesn't use divider.
There is a same simple explanation of limited output voltage too, but if he doesn't want to know...
PS.: Have the wires arrived?
Tekko said:
No! That pcb is not even made, im talking about a protoboard prototype, where the caps are 1-2 millimeters away from the fets legs. Tho they dont do mutch, im staring to think that it may just be the probes i have to the scope that creates what i see on the screen.
My probes isent real scope probes, but probes from a 20+ years old pulse echo meter used for checking long cables for faults.
