Legato 3 - Look ma! No caps!
How can I be sure the power amp can handle the DC from legato 3 ?
Is there any test procedure ?
I dont know if it is relevant but I had a problem when direct coupling Ventus with my power amp.
There was a hum. The problem solved when I used a tin foil capacitor.
But I prefer the sound without the capacitor
Just do not connect ground between legato and your power amp. Without ground, there is no DC, and no problems.
Yep, it is a RC HP-filter of the 1st order with a cut-off at (2*pi*15u * 10k)^-1 = 0.94 Hz (-3dB). I could even use a 1uF cap but they are a bit costly and as I had three different pairs of VSF caps in the range 8u2 - 15u in my drawer, I just put the 15uF in and listened.
I have also tried the red-brown russian PIO // russian Teflon caps but the VSF is better, IMO.
/S
I know and that´s why I react on this extremely high value
It´s effectively a high-pass filter, right?
best
Leif
Thanks. I've just put some rifa pfr 2n2s in last night, but I'm not convinced. Sounds a bit flat and lifeless. Will have to try the pfes. I'm trying to resist ordering relcaps as I just can't justify the cost, but the niggle to try will never go away...
Interesting!
I sometimes use PFR:s as power supply bypass caps (10nF) but have not tried them as coupling caps.
Are the RelCaps available in 2n2?
/S
