I found a schematic dated 30 11 9
I need you to confirm the latest BOM and Sch.
http://www.diyaudio.com/forums/group-buys/155054-leach-amp-pcb-group-buy-interest-5.html#post2141949
its post 242
I am going to place my order with Digikey in the morning. Does anyone have anything they would like me to add and ship to them. Most of what I am getting is the resistors and silver mica caps. I am going to try and find some Cerafine or better for the small on board electrolytics.
I found a great price on the output resistors at Pridmore on Ebay. They look like quality items. I am going to use the 0.47 that Jens recommended to help with stability even though it might rob some power. If after I do some measurements I need to change then so be it. I will try an implement the voltage regulator's that Bob Ellis and Jens collaborated on some years back for the frontend.
If anyone finds a really good price on the output devices 3281 or 4281 please post a note. These guys are expensive if you need 48 units. Ouch. A lot worse if you are going to match.
I am waiting for a reply from a fellow member on 100 volt Kendeil power supply caps from Istanbul. He seems to have a good source if shipping does not eat up the savings.
Tad
Tad
Luke,
C1=1uF sounds right.
C12=470uF seems completely wrong.
Rin=22k. An input cap between 1uF and 10uF should allow sufficient unattenuated bass for all music and sound effects lovers.
C15&C16 are the NFB blocking caps. These should never have any AC signal across them. The value for C15>=1.414*[C1+C12]*R43/R40
if the input caps are 1uF then C15+C16>=31uF
if the input caps are 10uF then NFB caps >=310uF
C4 & C22 are discussed in Leach's Lo Tim paper.
I hope you already have a copy and know it off by heart. Print it out and keep it close by.
Tad,
My components supplier is EPCOS authorized dealer here in Brazil. I bought 10.000uF/80V capacitors at about U$6,00 each. If you want some, I can buy it for you and send you. My pleasure! Those caps are 35mmX50mm snap in types (10mm spacing).
And if anybody else wants those caps, I can send you.
80V capacitors is fine if using +/-65VDC supply.
Hi Ed,
Yes, they have the GigaElco capacitors (those with screw terminals).
I don't know if they have it in stock, but the price is:
22.000uF/100V = U$29,00 (B41874 series - 50mm diam X 116mm tall)
They also have 10.000uF/100V snap-in, but the price isn't good: U$18,00.
If you want any of those, let me know, so I can call them and see how many they have in stock.
Hi Guys,
just been looking at the BOM again and have some questions.
1./ Why is the input cap 470uF, this seems really high for an imput cap, generally they are 2-5uF. If I have to go really high is 100uF bipolar high enough, I have some in stock?
Probably a typo. Looks like a bypass cap. Probably meant to be 470pf.
Toshibas
I can now follow up my reference to Toshiba output transistors in post #301 with the following:
I have 2 quads of them in 2 channels of AAK's DTV Symassum playing right now. Just fired them up.
They work well in his boards, providing 4 & 8 mV DC offset @ 40 mV bias.
The Low Tim amplifier uses a 390pf silver mica input cap per the parts list on Dr. Leach's website.
Tad
Tad
Hi Tad,
before you buy, check this guy out, he has alot of the leach parts for a good price.
Emmiter resistors, silver mica caps, hardware and pots.
eBay Stores - diy-stand, Capacitors-electrolytics, Resistors items on eBay.com
Luke,
thanks Andrew, the 470uF input cap is on all of Jens boards, I dont get it and would rather use a film cap.
Ill leave c15 and 16 as per the BOM.
Have read parts of the Lo Tim paper but will revisit before building.
Tad
Hi Tad,
this one just shorts rf to ground, there is one in Jens board that blocks DC or LF. I think I may jsut leave it out, Ive got 2 preamps and they are tube with output caps.
just reading Dr Leaches papers and he states that the cascading resistors Q5 and Q6, (Jens latest diagram T10 and T19) drop the voltage by about 18V. I dont understand this, if the zeners put 40V at their bases then wont they drop 40V plus Vbe of 0.6V?
0.6 is very very very small compared to 40 volts don't you think? so that it can be ignored.....😎
yes very very very close🙂 I wanted to show how I calculated the voltage on the input pair. But it all makes sense now, I think he used 58 v rails so 58-40 is 18 dropped across the cascade. I was thinking of 80 v rails which is what Im planning so I thought he was wrong;-)
would 2sc5171 and 2sa1930 be a good substitute for for the mje15032 and mje15033?
They have the same pinout so that makes it easy.
I worked out that if my outputs have a minimum hfe of 25, for an 8 amp output, the driver would need to deliver about 320mA I think. This device is good for 18V and 2amps Ic. What's the verdict, will it work?
vas or predriver is the preferred position for 2sc5171 and 2sa1930 imho.....but you can use them if you have them on hand.
- Group Buys
- Leach Amp pcb group buy interest
