This is a current source amp ?
If I've understood correctly no, but not a pure voltage source either. The output impedance is about 4-8 I think.
Found this heat sink and thought it might work well with the L'amp 193v or inductor version.
NC-441K - Hardware, heatsink. Dimensions: 5.5" long.
Can i use SIT choke version to drive hifiman headphone series which impedance vary from 35 to 50 ohm?
yup
be careful , to not blow your eyes
put some series resistor or make resistive divider
ears? 😉
ears? 😉
First ears, then eyes!
With eyes you can still make DIY amplifiers!
Who needs ears!
Rush
ears are choked with headphones , so only ears can pop out
you mean only eyes can pop out!?😕
Also asked myself the question. One day i shall try with higher B+ and less amps. Might suit the SIT even better. 🙄
one more question, suggested power supply use CRC with 1ohm which seem higher than standard FW series, i don't the purpose whether to limit current or drop certain voltage. So can I use CLC supply which will also supply my AlephJ? I'm planning to put the psu in different chassis, hence I can switch and play with different amp.
now prioritization is always difficult, impact analysis,severity, and complexity just like my daily work. my dac will cost more+longer built than AJ+SIT
what ?
😀there is another working point to cut half dissipation for headphone ?
ps I have the KE ones.....
- L'Amp: A simple SIT Amp
