I've got some LAB12 speakers, wood, fasteners, MDF etc ready to go. I'm going to build one LAB12, and if I like it, I'm going to be building some more for a DrumNBass setup.
I have all the tools and necessary skills to build the thing and make it look great, but I'm not sure what to buy for a few things:
1. terminal plates for 1/4" plug (mono?)- where do I get the best terminals to connect 1/4" plug into and what gauge of wire should go between the terminal and the speaker? I was assuming 8-gauge, but I've seen images on the forums with skinny wires between the terminals and the speaker, doesn't look right to me.
2. What's a good heavy duty recessed handle? Do any of them allow you to lift something this heavy without cutting off the circulation to your fingertips? (like a thicker handle)
3. I was thinking about cutting off the back lower corner and putting wheels there where the Pi 12 has wheels - anyone ever drag these around with the wheels? Is it helpful, or just a PIA? Seems like, even thought more effort is required, one person on each side grasping a handle will have better control...
Thanks in advance, will post images once we get started.
-Bouki
-Bouki
