L-Adapter
Rpi 4 specifies 5.1V 3A PSU. This is 15.3W ability not fully used. At least not all of the time or without heavy peripherals.*
Your Fluke meter shouldn't have gone off scale in Ampere series measuring mode. Maybe there is a shorted or reversed end plug/cable?
Dummy tests for this kind of rail & load range take three 4.7Ω/10W resistors. One pulls 5.1V/4.7Ω=1.085A. Paralleling a second one pulls 2.17A. Paralleling a third one pulls 3.255A.
Those tests aren't sustainable with small on board Q2 heatsink for long. Short time tests only. But if passed without considerable rail dropping and LEDs not extinguishing it means there's no problem with your PSU configuration & parts even for 3A peaks and bit more.
*RPi Power Benchmarks
I've soldered most parts except for a missing IC1 regulator. But I also realized I forgot any thermal pads or paste between the heatsinks and rectifiers/transistor(Q2). I only want to confirm that I really need the thermals, then I will try to arrange it without desoldering...
EDIT: just read the guide again and understand that it is not needed when sinking is done on board. Correct?
Hi, there's no detailed drawing sketch for dimensions. As mentioned in the guide PCB size is 136mmX63mmX2mm. Its mounting holes diameter is 3.6mm. Their horizontal center to center distance is 127mm. Their vertical center to center distance is 54mm.
Reactions: KeLLoGsX
Two more Ladapter ‘s for a friend in Cyprus ready!one for raspberry pi,one for router.thank you again @Salas !
Reactions: Chymist and Salas
I looked through and did not see anything about this - is there a way to get 24 volts?
I want to build a supply for the SOTA Condor motor controller and think L Adapter would be good if this might be possible.
Please excuse if this is the 88th time you have answered this.
Thanks, Salas
PS now I see the post where the fellow is using the L ADAPTER to power an amplifier (I think it was) and your only concern was current through the LEDs.
This supply will supply 1 A current at most - that was the value of the wall wart supplied with it.
Would lowering the value of the current set resistor for LM334 be advised?
This will not need to be adjustable so I will not use the specified LED block.
Do you have a favored single LED?
Hi, the answer is also in the pdf guide:
"The jumper should only be moved in parallel to the LEDS across the two rows of pins.
Not vertically on single row. No jumper at all allows for all the LEDS to operate when the
transformer has enough output. Each added LED contributes about 1.75V extra. 17.5V total +
2.5V from VR1 maximum. For >20V needs, using 2kΩ VR1 can extend Vout to 27.5V max."
Lowering of the LM334's current set resistor is not advised. That decreases its current source impedance, it's no good.
Favored single LED hmm... HLMP-6000 is supposed to be a really low noise type. Although it has an unusual form factor.
Reactions: rickmcinnis
Its better to add more Leds if you can. Because of their less impedance than adding much voltage from the pot alone. Keeping the IccsZ/VrefZ ratio higher. That's good for better ripple rejection. But do have a pot to can easily adjust your 24V target.
A question about transformer wiring. I have a toroidal with 2x9v secondary, which I will wire in parallel. According to the schematics that means wiring together black/orange and red/yellow. Correct?
My simple question, does it matter which connector each pair is connected to at the input of the l-adapter?
So far so good. Have the adapter, transformer and switch hooked up. Set it to 5v. Now I'm trying to figure out the best way to connect it with my new Raspberry Pi 5. I'm trying to find a USB-C to pigtail bare ends wire that can carry a max current of 5A as per the RPI 5 specs but it isn't easy. Or should I strip a regular matching USB-C cable and find the power wires...
Do any of you have any good ideas?
Got the L Adapter working for the 24 volts supply for the SOTA Condor turntable motor and I have another one of "those questions".
Using the HLMP-6000 leds I found I needed more than twelve so I added two more. I think 15 would allow using minimum resistance to have 24 volts. I put them on a small perforated circuit board and have them connected at the first led position.
The question is: Is it best to use as much "led" as you can or is it good to have resistance in addition to the leds? I am guessing I would only need about 100R with another led in the chain.
Does it matter at all?
At your leisure ...
I think there is something gained with the L Adapter versus SMPS and I was using a more robust SMPS than was supplied with the kit. Will have to listen longer to make sure of that.
THANKS, yet again for these regulators, Salas.
Reactions: Salas
